Moisture inside manifold
Old Jan 19, 2019 | 04:05 PM
mattcl-s's Avatar
I took off the top plate to clean the manifold out today and notice what looks like tiny water beeds on the top plate gasket, has anyone seen this before? My car has been in the garage since November. I ordered all new plenum gasket set from rockauto just to be safe
Old Jan 24, 2019 | 03:11 AM
lateralus's Avatar
wonder if its condensation ?
Old Jan 25, 2019 | 06:19 AM
Iggy's Avatar
That was my guess.
OP, how long did the engine run after sitting in the cold until you brought it inside to work on it?
Old Jan 25, 2019 | 05:28 PM
mattcl-s's Avatar
thats what i was thinking I was curious if anyone else seen this before. I got the new gaskets ready to intall
Old Jan 25, 2019 | 05:31 PM
mattcl-s's Avatar
Originally Posted by Iggy
That was my guess.
I took it out for a drive couple of weeks ago when it was 40 degrees its been sitting in the garage since then with a small space heater every now and then. So between when i drove it then started taking it apart was probably 2 days
Old Jan 26, 2019 | 08:24 PM
01acls's Avatar
The moisture is from the air/fuel mixture blow by of the piston rings. The motor oil will keep the water suspended until the next oil change if the car is driven regularly.
Nitin
Jul 28, 2014 10:35 PM
bdfein
Jan 7, 2006 01:44 PM
ricksvt
Nov 11, 2005 09:31 AM
JPritch
Mar 2, 2005 02:52 PM
