Modding woes. . . help needed!
Alright so here's the situation I just lowered my car 2" F 1.5" R adjustable Tockico shocks. When accelerating I'm getting a feedback through the steering wheel and can even feel it in the gas pedal similar to when you have an unbalanced tire. . . but I know it's not the tires. I've had this issue before but only when it was cold out and I would accelerate up a hill. . . that time I replaced the C.V. axles and it fixed the problem. So I'm thinking it may be axles again or possibly engine mounts (I'm on stock mounts and dampers). Also I've been fooling around with the adjustment on the shocks softer seems to absorb the vibrations a little bit. . . Any experience or advice is greatly appreciated. In the mean time I'll keep fooling with shock adjustments and see what that does.
well since u lowered the car the axles are now rotating on a different axis which could induce ur symptom presuming it was not noticeable when u were at stock height .. as for engine mounts there is barely a different load on them now that u are lowered (aside from the angle of the car which will transfer the weight on the mounts a little differently.
but it sounds like it's something that's rotating.
but yea i'd likely have to point my finger then at ur axles :-(.
seems like the newest problem the CL is having on the forum with all u 6 speeders.. axles just aint cutting it
do ur axles have a warranty on them ?
Yeah usually how it goes . . .
Any recommendation on axle brands? I know civic you've snapped a bunch of the GS P ones those I could get the cheapest at a little over $100. Anyone have any experience with Duralast (Autozone) or Master Pro Select (Cardone/O'Reilly's)?
TLDude876
Dec 28, 2016 03:18 PM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
sockr1
Oct 1, 2015 01:31 AM
