Mobil 1 oil filter
Check this out b4 you plunk down your $$ for a Mobil 1 filter.
http://members.nbci.com/minimopar/oilfilterstudy.html
2001 Satin Silver Cl Type S.
Comptech Headers
Comptech Springs
Muds
Wheel locks
35% Llumar metallic tint
Best 0-60. 6.08 Gtech Pro (Preheaders)
My Car
Comptech Headers
Comptech Springs
Muds
Wheel locks
My Car
After reading the link above, and as I'm still learning...
what's the consequences/risks of
buying a non OEM authentic acura filter?
Does anyone know how much the OEM costs?
Seems to me like the Mobile 1, Purolator (Proline) are good safe bets..
and I would be using Mobile 1 Synthetic anyways, keeping it simple would be good.
Besides, don't have to use "special tools"
to remove it..heeh Honda/Acura designed their parts to be used by Honda/Acura tools...
isn't that anticompetitive?
- Kvit -
2001 CL-P Blue Sub 6
*Polarg BlHybrid M-6 Road lamps
*Polarg BlHybrid M-14 Turning Signal/M-4 Side Markers next
http://albums.photopoint.com/j/Album...725&a=10358832
- Kvit -
Powered By HONDA
yah i am using mobil 1 5W~30W full sythetic oil every 3000 miles with acura oil filter..give better to your lovely car is worth
Red CL Type S.
Powered by HONDA
Powered by MUGEN
Red CL Type S.
Powered by HONDA
Powered by MUGEN
I'm out of HELL!!!!
If anything, that website only further proved that Mobil 1 filter is the way to go.
Of course, the page only had two synthetic filters listed.
2001 Acura CL Type S. Satin silver, non-nav, #848
1997 Ford Probe (POST)
oem oil filter costs between $7-10, i recommend using one from acura it is made specifically for the cl unlike a mobil 1. I would make sure that you replace the crush washer every time on your oil drain plug. If this is not replaced it could cause damage to your oil pan. When you do not replace this crush washer it could cause oil leaks that would not be covered under warranty. The same issue is brought up when using aftermarket oil filters. If this causes an oil leak it would not be covered under acura warranty
Coming to a city near you
You can get some good deals on filters/parts from my friend Mike K in Naples Fl. Call 1-800-79-acura and ask to speak to mike in the parts dept. He should be able to hook you up with OEM parts. If he asks about how you heard about him either tell him the hybrid board or tell him that Adam sent you. That is who I bought my brand new 00 ITR engine from. If people want I will email him and get some prices on buying bulk filters.
Wow only on my 2nd tranny
<font face="Verdana, Arial" size="2">Originally posted by pv22clif:
oem oil filter costs between $7-10, i recommend using one from acura it is made specifically for the cl unlike a mobil 1. I would make sure that you replace the crush washer every time on your oil drain plug. If this is not replaced it could cause damage to your oil pan. When you do not replace this crush washer it could cause oil leaks that would not be covered under warranty. The same issue is brought up when using aftermarket oil filters. If this causes an oil leak it would not be covered under acura warranty</font>
The crush disks are available at the dealer. If you ask for a handful they'll usually give them to you, otherwise .25 each. By all means use'm with your Mobil 1 or other filter. I've never seen one that looked worn at oil change time, so if you have to reuse one in a pinch, I wouldn't stress to much about it.
Powered By HONDA
how much is a mobil 1 oil filter? and how much is a acura/honda oil filter?i think acura/honda filter are made for inter useable for all honda and acura cars..no specific oil filter for specific cars..
2001 Acura Red CL Type S.
1997 Honda Civic EX.
!!!! VTEC Power !!!!
Powered by HONDA
Powered by MUGEN
typescl@yahoo.com
Powered by HONDA
Powered by MUGEN
![](http://www.geocities.com/b18cvtec/1.jpg)
typescl@yahoo.com
rcs86
08-02-2016 06:52 PM
