"Moan" from '02 CL-S
Old Feb 13, 2002 | 04:40 PM
mat347's Avatar
I was working on the Mustang the other night parked next to my CLS when I heard a "moan" come from under the car. It sounds like some sort of small pump and the pitch changes as if it is getting a load put on it. It only stays on for about a second, and re-occurs every 10-20 minutes. Just wondering if anyone else has heard the same, and what it might be.
Thanks for any info...
Old Feb 13, 2002 | 05:48 PM
DtEW's Avatar
Sounds like it's jealous.
Old Feb 13, 2002 | 06:16 PM
Samer007's Avatar
Smack My B*tch Up
I think those are the brakes system ( the hydrolics are pumbin)
Old Feb 13, 2002 | 06:59 PM
Fabvsix's Avatar
Cajun Gumbo Man
that is the ABS system !
Old Feb 13, 2002 | 07:15 PM
Red Nj-s's Avatar
Why is the ABS workin when the car is parked? Does it have sumin to do wit the parking break? Or is it jus "rejuvenating" itself.
Old Feb 14, 2002 | 08:36 AM
mistacanyon's Avatar
Mr. PC
Could be the hooker in the trunk. I've had that happen tons of times!
Old Feb 14, 2002 | 09:45 AM
digitalgm's Avatar
"v1 saved my ass ......."
dude, tell me about your stang -- I noticed you got "347" in your name so spill it....
AdamR
digitalgm's Avatar
I hate when they cant just shut up! smack dem hoes!
AdamR
Old Feb 14, 2002 | 12:30 PM
spidermike9's Avatar
mine does this too. Its normal. I posted the same question a few months ago and a lot of people reponded that their cars did this too.
Old Feb 14, 2002 | 12:34 PM
HellaWhat's Avatar
*Hella* isn't a word.
The A/C Condenser turning off.
Old Feb 14, 2002 | 04:48 PM
mat347's Avatar
Well, the ABS makes more of a grinding "buzz" than this noise, plus its from the middle/rear of the car, not the front. The car can be sitting for hours and Ill come out and itll do it. It drives my dog NUTS when he hears it, he tries to attack sompin under the car, its quite funny actually.
I did a search and couldnt find any other topics on this, I guess I used the wrong words to search. But Ill have to get up under there and take a good look at stuff. We do have return-less fuel systems and was thinking it could have been the fuel pump for some reason, but they make a higher pitched whine I think. The more I think about it, the bigger my curiosity grows, Ill just check it out when I have time...
and digitalgm....True, the GT has just about everything you can get for a N/A road-race setup....Ill TRY to make this brief!!!
forged everything 347, fully machined block, polished bores, etc....
Main stud girdle, machined for 1/2" head studs.
AFR 205 heads, fully CNC'd from AFR, 1.72 7/16" DSS stud mount rockers. Steel cam sprocket that has been lightened for less enertia, Custom hydrolic roller(maybe solid one day) .550/.580 225/236@.050 289/299 adv. duration.
TFS 'R' intake w/1" spacer
75mm Edelbrock TB
80mm Pro-M composite MAS w/AFM High-vol fenderwell power pipe.
36# injectors, Aeromotive fuel rails, 255 intank pump.
Battery relocated to the rear.
1-3/4 Jet-hot BBK longtubes, 2-1/2 off-road, 2-1/2 Force II (3-chamber) flowmaster cat back.
Baer 12" A-sedan certified 4-wheel disks
Centerforce DF clutch on Mcleoud(spelling) aluminum flywheel
Tremec 3550 w/Steeda Tri-Ax, SVO aluminum DS(soon to be carbon fiber), 3.55 gears, T/A girdle.
Tubular K-member/A-arms/coil over Koni yellows, Hotchis CC plates.
Strut tower brace, Baer bump steer kit, Flaming river steering shaft.
Subframes, MM panhard bar, MM adjustable rear swaybar(front is next), MM T/A (not installed yet due to exhaust clearence problems).
MM LCA w/adjustable spring perches, H&R rear springs.
Clarion 9375r Head unit w/9300 DSP processor (fiber optic connection)
50x4 Alpine Expert amp for mids/highs, 75x2(400x1) for sub.
Boston pro 6.53's up front, 6.5 in doors, 4" mid in dash, Neo4t(titanium) tweeters on mirror plates.
Diamond Hex 6.5 rear mids w/Neo 4t tweeters.
Boston pro 12.5 sub in custom MDF box.
System is loud n clear with a bit of clean thump when needed/wanted.
I havnt taken it to the track with the new setup yet, but the best was 12.20 with the 302/Edelbrock heads/GT-40 intakes. I expect mid 11's on motor, I still have 100 shot of insurance if needed. Im buiding this car to be a weekend street car capable of beating a stock Viper every way possible(stop, go, twisties, top end)
My goal was to run 11's on motor, 180+mph, and over 1G in the turns. I believe I exceeded in all aspects, but Ill have to go to the salts to check that 180MPH top end, I dont want to get THAT stupid on the streets.
But I also have an 86 coupe that I will start on after I finish the GT which will be an all out drag car, I guestimate 9's on motor, 8's on the gas. I dont have any time expectations, Im just going to build a good combo and be happy with whatever it runs. The car is only 2400 LBS with only being striped and a fiberglass hood. I still want to go Lexan/fiberglass doors/trunk/fenders/k-member, etc...
I will need to add a cage and a few other braces, but I expect to keep it around 2300lbs. And it doesnt take much to get that down the 1/4!
SORRY SO LONG!!!
Old Feb 14, 2002 | 04:52 PM
mffdvr's Avatar
DAYUM!!!!
Old Feb 14, 2002 | 06:32 PM
Nicky Pass's Avatar
Fuct in the hed!
It probably just everything cooling down.
Old Feb 14, 2002 | 06:37 PM
CL-S-Bo's Avatar
I tend to refer to it as a farting sound.
Old Feb 14, 2002 | 10:05 PM
jtree007's Avatar
My 1999 Honda Accord and my Cls do it so I think it is something normal with Honda cars. I would love to know what it is though. I have tried but never figured out what it is.
A alittle bit off topic, who on the board has a classic Mustang?
I have a 69' 390 Mach I in factory original condition.
Old Feb 15, 2002 | 10:12 AM
Glenn Davis's Avatar
CL Expert
That sound is perfectly normal. My 98, 00, and 01 EX V6's all do that. It's the fuel system. After the car is shut off, there is still pressure in the fuel system.
That is what causes the various sounds that can be heard.
To stop it (and verify that it is the fuel system causing this), simply unscrew the gas cap with the car off and parked. It should hiss a little as all of the pressure is released. After you put the cap back on, it will stop the moaning/mooing/ringing sound that you hear.
But it's no problem.
Old Feb 15, 2002 | 10:14 AM
digitalgm's Avatar
I have a classic mustang - 1965 289 Fastback =)
AdamR
Old Feb 15, 2002 | 04:02 PM
Blue's Avatar
It's your fuel being sprayed into your injectors...This not only affects Honda/Acura but other makes as well... It's totally normal...
Pham Alvan
May 18, 2021 06:48 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
RSpyder
Sep 30, 2015 12:46 AM
Gary Matthews
Sep 11, 2015 01:21 PM
debaser
May 2, 2001 11:22 AM
