This might be the big one
Old Mar 17, 2008 | 03:59 AM
g1underground's Avatar
Cosmic Cowboy
Haven't driven the car in two weeks so Friday night coming around an offramp about 35 mph when the check engine light came on and lost power then felt like I lost a cylinder. I pulled over and heard a tapping from the left front corner of the cylinder head. I was about a mile from an Acura dealer ( Chevy Chase Acura ) and dropped in the after hours. Saturday morning the service manger called sounding like a doctor with bad news. Mike ( if anyone in the area is familiar with him ) said they have to remove the head Monday but it doesn't sound good. The engine never quit, no leaks,smoke or sounding never ran hot. Plenty of oil and coolant. I'm thinking shot rocker arm and bent valve. Only 79400 gentle miles, don't remember reading anyone else with this. Never had a drop of trouble with her. Update later on Monday.
Old Mar 17, 2008 | 08:31 AM
Moodist's Avatar
Ouch doesn't sound good. Do you have a 6-speed? Also, I hope you have an extended warranty. Good luck.
Old Mar 17, 2008 | 09:31 AM
Cosmic Cowboy
Yes to both, the warranty should cover the internals. Just seems kinda rare for that engine to go out like that.
Old Mar 17, 2008 | 10:15 AM
Cosmic Cowboy
UPDATE..........and please I hope a more knowledgable member reads this.
The dealer is saying iridum spark plugs melted my first cynlinder coilpack and damaged the head - $3300 for head replacement, $300+ dollars for platinum plug replacement. He's telling me our cars should never use iridum plugs because it did not come from the factory like that Now I know that's bullshit.
And not covered by extended warranty.
Old Mar 17, 2008 | 12:08 PM
NSXNEXT's Avatar
Might be time to brush up on the Magnuson-Moss warranty act and maybe consult legal representation.
http://en.wikipedia.org/wiki/Magnuson-Moss_Warranty_Act
Lot's of people runing iridium plugs on their CL/TL with no problems.
Old Mar 17, 2008 | 12:35 PM
260TYPESNY's Avatar
wow man im sorry to hear that. let us know how this goes. good luck
Old Mar 17, 2008 | 12:41 PM
fsttyms1's Avatar
Problem is is in the fine print of most of the aftermarket warranties anything other than stock is grounds for voiding warranty.
To the OP, id use this link and pick up a used head for a few hundred bucks and save a ton of money
http://www.car-part.com/index.htm
Old Mar 17, 2008 | 12:42 PM
FordDan's Avatar
Post #18
Posts: 5 wewewewewe
wewewewewe
wewewewewe
wewewewewe
wewewewewe
wewewewewe
wewewewewe
wewewewewe
wewewewewe
wewewewewe
wewewewewe
wewewewewe
wewewewewe
wewewewewe
wewewewewe
wewewewewe
wewewewewe
wewewewewe
wewewewewe
wewewewewe
Old Mar 17, 2008 | 01:03 PM
EL19's Avatar
wtf^
Old Mar 17, 2008 | 01:06 PM
distortedolskool's Avatar
i already sent greenmonster a PM. one IP ban coming up!
OP-
everyone i know has run iridium plugs. best of luck fighting those dealership idiots.
Old Mar 17, 2008 | 01:36 PM
underst8's Avatar
140,000 miles young
Yeah, that's a load.
Old Mar 17, 2008 | 02:15 PM
typeS6S's Avatar
3.2L Vtec
if you can prove that the irdium plugs are replacements according to the manufacture then you should be covered. At least that is an argument I would bring up
Old Mar 17, 2008 | 03:48 PM
aznboi2424's Avatar
Assuming you have a CL-S 6 speed, they come from the factory with lazer iridium plugs. Only the 01-02 CL-S comes with lazer platnium plugs.
Old Mar 17, 2008 | 03:53 PM
Zippee's Avatar
How long have the plugs been in?
Only way I can see them causing a problem is if they are the wrong heat range or they were installed improperly-likely left loose.
Old Mar 17, 2008 | 11:00 PM
Cosmic Cowboy
OK......another update
The dealer now said that the 03 did come with NGK iridium plugs but not NGK IX iridium plugs that was found in the car, in for at least 4 years since I've had it. Now I checked various catalogs and the IX is a update for the older model same heat range, thread everything for an 03 CL. The extended warranty people did kick in and will replace the coilpack and rethread the damage cylinder where the number plug supposed to have heated and blew melting the coilpack. The head itself was not warped but now ONLY standard NGK iridium plugs will be installed ( still 300 dollars...not covered ) and should only be changed by a dealer after I get to 180,000 miles or another seven years whatever comes first.
I'm glad it's covered but I still feel scarred by the Dealer Dance. So hear's a little heads up to y'all, they will try to find something.
At least a got a 08 TL as a loaner...sweet ride
Thanks again all for info and support
Old Mar 17, 2008 | 11:25 PM
Allout's Avatar
Blown is Best
I'm glad they came to their senses and are going to take care of you. What they were telling you was a bunch of
Acura604
2G RDX Photograph Gallery
17
Feb 8, 2021 03:32 PM
Jul 16, 2017 07:33 AM
Jinkazetsukai
Nov 21, 2015 05:28 PM
Froid
Sep 27, 2015 06:16 PM
