Memory Seats
3rd Gear
Memory Seats
This might be a silly question, but I just bought a 3.2 CL w/out an owners manual, and I cant figure out how to set the memory on the power seats.
Please advise,
Also is there anyplace I can download an owner's manual?
Vince
Please advise,
Vince
1) adjust the seat
2) push the red button
3) choose the memory location (1 or 2)
Make sure the gear is at "P". If it is 6spd, then make sure it is at "N" and pull the handbrake.
is Pretty Much a Moron
1 Post
With the ignition in the ON position, set it to the desired position. Then press the red MEMO button. The lights next to 1 and 2 will flash green, press one. The one you choose now remembers your position.
Originally Posted by anothercls
Set the seat and mirrors where you want it, then press the red button and select which one you want to use, either one or two, depending which key you want to use to open the door.
beat you to it..
You have five seconds from when you press the red button for choosing position one or two.
If I remember correctly, you will get one beep with the red button, and an acknolwdgement of two beeps when you select one or two.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
