Max power on stock injectors
What's the most power anyone has made on stock CLS injectors? I'm considering a CLS engine swap into my Accord. I'm making around 280whp on with the J30 motor with SC (8.5psi). This is with 440cc RC injectors and 1:1 FPR. That boost level will drop on the CLS motor, how much I'm not sure but if I had to guess ~7psi. Would the stock CLS injectors be able to handle that?
The reason I'm asking about the stock injector is because I want to retain daily drivibility. With the 440cc injectors, daily drivibility is complete sh!t. Going from 240cc injectors -> 440cc injectors is too much for the stock ECU and Emanage. With the CLS motor, I plan on using the stock injectors and putting the Comptech FPR back on. Tuning will still be done with Emanage. What do you guys think?
I didn't want to spend money on another set of injectors. Shot in the dark but is anyone interested in a trade for S2K injectors for 440cc RC injectors.
https://acurazine.com/forums/showthread.php?t=189890
Awesome, thanks CleanCL. I did search but I guess I missed that post. Well according to that thread, the stock CLS injector should be more than capable to handle the power I will put down if I do the swap.
I see that you are running E-Manage and an Aeromotive 1:1 FPR. The power listed above was reached using the E-Manage and Comptech's rising rate FPR with different washers than what is supplied with the Comptech kit. While the E-Manage allowed them to lower the fuel pressure a bit by increasing pulse width the fuel pressure at WOT was still considerably high (~90psi on supercharged applications)
k6biv
09-10-2015 06:37 PM
