Max Boost Pulley
Max Boost Pulley
Anyone know where i can get a max boost pulley from but not the payne tech one, i had one that i bought from serge wasted my whole day today doing that and the s2000 injectors started the car to bring it to tune the e manage and before the car even turned over the pulley broke in two pieces it was such a thin piece of shit! i really need this pulley so i can get the car tuned i can't drive it like this it is pushing to much fuel in with no tune and i am not going to pay twice. HELP!!!!
Steve,
Sent you email. This I heard a solid company which I believe also scalbert ordered from - http://www.southfloridapulleyhq.com/SFPH/about_us.htm
The blower shaft MAX pulley you need is 3.3".
You can run on alternator HBP at this point and factory 3.8" shaft pulley until you receive the MAX.
Yes, 3.5" would be safer while 3.3" is required top mount intercooler or at least meth injection (w/smallest nozzle) as I suggested before.
Make sure you tuned as lean as 12.0:1 at WOT but better to stay within 11.5-11.8:1 AFR range.
Hey ron, No you do not need injectors with the high boost pulley, i was running fine with factories. I am having a 9.5 max boost pulley made so i needed to replace them, I also am doing a e-manage blue.
MP90 uninstalled
Some of you know about me retrofitting the MP90 to the Comptech kit. I am using new 440cc RC injectors(calibrated), a boomslang harness, Emanage ULT, and stock FPR. I used the HBP on the alternator, stock blower shaft pulley, and underdrive size UR pulley to get 9psi. I will be selling the whole kit and car once I get it all together if one of you wants it. It should to wonders particularly for the 3.5L guys who want to run 7-14psi. I should have it done by January. Should be interesting. The kit is all done and fits perfectly with the hood closed, just need the tune. I need time to go have it tuned so the car will run with the 440cc’s and I can make a top notch map for the eman ult. I went back to the stock FPR because at the stock fuel pressures the 440cc’s will make up to 500shaft hp and the Comptech FPR is so damn inconsistent. Some of you with the blower may have noticed rough startup from the injectors running all over the place psi wise. I went back to the stock FPR without the blower on in prep for the MP90 and the car purrs like a kitten now during all driving conditions and even has more power. My Comptech FPR has been rebuilt and checked several times. Nothing is wrong with it. I hate it and the A/F ratio is never consistent with the Comptech unit on the dyno.
BoricuaTL
04-08-2016 01:08 PM
NBP_BALLER
09-23-2015 08:18 PM
4drviper
09-23-2015 07:42 PM
