MAP Sensor
MAP Sensor
I have an Acura CL-S 6mt. I have been throwing two check engine lights. P0170 and P0172 (running rich). I thought it could be the MAP sensor causing the problem. It is missing the piece at the bottom. I have attached a picture.
Do you think this could be why I am throwing codes. I had my o2 sensors tested and my fuel pressure checked. Those were fine. Let me know. Thanks in advance
When you took it off, did you see a hole in the TB where that piece would reside? If so, then yes.
I doubt that it would break on it's own....it must have broke when removing it.
Yeah there was a hole big enough for a piece like that to fit in. I doubt I broke it when removing the map sensor, I think the previous owner must have broken it. I will try replacing the MAP sensor and see if this fixes my issues.
My car smells bad at WOT (burning smell), it bogs once in a while, and sometimes a rough idle.
soupi
14
11-15-2015 11:15 AM
ExcelerateRep
10-14-2015 08:20 AM
