M/T Tranny fluid- How many quarts?
B A N N E D
Hey guys, I went to Honda today, to buy some clips for my pillar, and asked about the M/T fluid, guy said its $5.30 qt. Iam planning to change it this weekend, I have a couple of quiestions, how many qts do i need and is there a DIY for tranny flush/change.
Back to a MT!
2.3 qt (ie buy three) its not hard, the information in your owners manual is really all you need. I unhooked my intake to get to the fill hole easier, but a pretty simple process.
here you are: https://acurazine.com/forums/ramblings-12/valentines-day-haiku-93452/
Also, if you have a couple of ratchet extentions you won't have to remove the intake, also get yourself a a special tranny fluid funnel with a rubber tube attached to the bottom. This will make filling the fluid up pretty easy.
CURBS FTL
Originally Posted by Moodist
here you are: https://acurazine.com/forums/showthread.php?t=93452
you can also get like this syringe thing from autozone that you suck up the fluid with, then squirt it in the hole. it s a bit easier because you dont have to hold up the funnel in funny positions and you dont have to take off your intake. just fill it up until it starts coming out of the filler hole and you nkow its full.
Pham Alvan
03-16-2016 09:17 AM
