Loud ticking with AC on
Old 09-13-2007, 09:07 AM
metalguitarist.org
CQ7String's Avatar
My car just rolled 100k (tranny #2, fingers crossed) and this morning when I tossed on my AC, a loud ticking came from the engine - with the AC off, the ticking goes away.
I'm thinking the compressor is on the way out, or that the pulley itself may need to be replaced. Has anyone else had this happen?
Any insight would be appreciated.
Old 09-13-2007, 06:23 PM
03 3.2 CL Type-S (AT)
colemab's Avatar
let me know if you figure this one out. I have a very similar issue and I took it to the dealership for a diag (among other work) and they said they couldn't find a problem.
I even mentioned to them that the belt might be stretched and/or a bent/loose pulley.
which is really crazy, you'd think they'd charge me for some BS just because they are the stealership.
Old 09-13-2007, 08:33 PM
ThinJim's Avatar
if you need a compressor, hit me up, have 2 good ones
Old 09-13-2007, 09:33 PM
fuzzy02CLS's Avatar
You really need to figure out where the noise is coming from. It could be a great deal of things. Even something not ac related.
Old 09-14-2007, 02:34 AM
Moderator Alumnus
BigLizard's Avatar
Didn't Ross think it he had the same problem and it turned out to be the belt tensioner? The bearings were going out or something.
Ross where are you?
Old 09-15-2007, 12:03 AM
metalguitarist.org
CQ7String's Avatar
I gave it a listen today, and it's definitely coming from the side of the belt, but I can't really pin down what's making the sound. It sounds like a baseball card in a bicycle wheel - the ticking gets faster when the RPM's go up.
Pretty peculiar, and a wee embarrasing since my car sounds like a total shitbox with the AC on. I'm going to drag it in next week and see what the dealership says, I'll post up if/when they diagnose it. Hopefully it's just a tensioner.
Thanks for the input guys.
Old 09-20-2007, 02:52 AM
arp408's Avatar
same problem
you guys know what this is?! This is just your ac shutting down once it has reached the temperature of the ac is set on. that's what the tech which the shop i got mine looked at.
Old 09-21-2007, 04:27 PM
colemab's Avatar
aro408k, thanks for the reply but I don't think this is my exact problem as mine happens at start up if on max a/c (recycle) with max fan and doesn't ever stop.
I think mine might be a bearing in a fan or pulley as it doesn't make the noise on non-recycle mode.
SexyRL
4G TL Problems & Fixes
08-19-2016 10:03 PM
DerrickW
11-15-2015 05:52 PM
Skirmich
10-01-2015 12:59 PM
merc009
09-29-2015 03:06 PM
TL14
09-24-2015 04:37 PM
Quick Reply: Loud ticking with AC on
