Loud Squeeling from front end
I need help figuring out what this might be. My car is squeeling, almost sounds like it's crying, from the front end. I did a quick brake pad change, but that didn't help. It only happens when the car is warm/hot, never when it's cold. It happens when braking and while not braking. I recently got my clutch changed...could that be a factor? Someone told me it might be my rotors or ball joints.
Any thoughts or help is appreciated.
Well...it's kinda fast...
Check your belts. One might be on the verge of dying or just in need of an adjustment. If it is the belt, it's more than likely the P/S belt. Also check the idler/tension pulleys to insure they're properly tensioning your belt.
+1 for belts ... one or more of the belts may be loose or dry rotted and ready to snap.
In the Mid-South meow
Originally Posted by SG81
but would a PS belt sound like metal scraping? i recently also had my timing belt and tension belt replaced
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
i'm going to bump his thread and ask him
![n00b](https://acurazine.com/forums/images/smilies/n00b.gif)
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
I would have guessed front wheel bearings... But after hearing that you've got the timing belt changed, I'll have to agree the rest that it might be a ps/tensioner/belt issue...
well it turns out my noise was something different. mine was the drive shaft rubbing something. it's weird b/c i had the exact same symptoms that cltypeslow had. after a quick adjustment, the car is back to its normal self. thanks for the help/suggestions guys
TLDude876
12-28-2016 03:18 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
