Looking for a little help (2000 TL 6spd conversion)
Old Feb 24, 2006 | 12:16 PM
fsttyms1's Avatar
As it says im looking for a littel help from the 6 speed owners and any given would be greatly appreaciated.
I have a 2000 2nd Gen TL that just had its 5th tranny crap out. I just picked up a 6 speed manual and am going to do a conversion myself. (including a type-s engine)
What i need from you are some pics.
1). I need to see some pics of where the clutch master cyl is mounted,
2). If possible where the clutch pedal is mounted.
3). A good pic of the center console (any one know if its the same length as the TL as ill have to replace for the parking brake)
Thanks in advanced
Kris
Old Feb 24, 2006 | 12:44 PM
fsttyms1's Avatar
P.S. Im not looking for a HOW to thread, as ive replaced the tranny myself twice now and am more than capable of doing the conversion, im just looking for a few pics to help aid in th eplacement of things to make things a little easier down the road.
Old Feb 24, 2006 | 03:03 PM
psychoRN's Avatar
RN are my initials...
good luck! maybe do a DIY?
Old Feb 24, 2006 | 03:10 PM
fsttyms1's Avatar
Yea when its done ill try to do the best DIY i can
Old Feb 24, 2006 | 03:35 PM
GreenMonster's Avatar
Kris, It might also be a good idea to buy the Helms Service manual and Electronics manual for the CL (6spd is covered in the regular CL SM). Lot of pictures in there...
I'll have to look up in the Helms to see where the clutch master cyl is mounted, because I have no idea where to begin looking for it
Old Feb 24, 2006 | 03:48 PM
fsttyms1's Avatar
Good idea (ill need that for the wiring im sure)
Old Feb 24, 2006 | 04:06 PM
fsttyms1's Avatar
Purchased the helms for the CL. hopefully the wiring isnt that much different from the 2000 TL.
Another Question, does the 6 speed have ABS, and TCS?
Old Feb 24, 2006 | 06:06 PM
ABS yes...
The 6spds don't have TCS (traction control) or VSA (vehicle stability assist).... that's for pussies...
We've got LSD (limited slip differential)... that's what real men need...
Kris, if you search for cupholder(s) you might find some pics of the console... Also look in the A/V forum... Head units and navi conversions might show some console pics...
I can't figure out where the slave cly. is, but I think it's near the reverse lockout solenoid (or backup switch)... I need to look at the helms and my car at the same time to figure out where the slave is, and it's dark out
I'll try to snap some pics this weekend...
Old Feb 24, 2006 | 06:10 PM
I posted this in a prior thread, here's a direct link to Jens list:
https://acurazine.com/forums/showpos...1&postcount=13
Jen used to work as a tech at Park Ave Acura...
Read this and pay close attention to the post by Jens... He was a tech at PAA (an acura dealer in NJ):
https://acurazine.com/forums/showthr...nsmission+swap
Some other reading material:
https://acurazine.com/forums/showthr...N+TRANSMISSION
Old Feb 24, 2006 | 06:38 PM
ChucksCL-S's Avatar
Welcome over here Kris, and good luck on the conversion!
Old Feb 25, 2006 | 03:04 AM
fsttyms1's Avatar
Thanks john for the info. I pulled the engine tonight and got the tranny out a few days ago. ordered the 6peed tranny earlier today, have the type-s engine sitting by. just need the little parts.
All the info is VERY appreaciated!
Kris
Old Feb 25, 2006 | 03:06 AM
fsttyms1's Avatar
Thanks chuck! better watch out.. Your not going to be safe for long!
Old Feb 25, 2006 | 09:21 AM
CL (sometimes called CLP's) have TCS, CLS w/ auto have VSA, and the 6spd has no traction control whatsoever (just ABS and LSD).
Old Feb 25, 2006 | 10:45 AM
fsttyms1's Avatar
Thanks. Im sure that is something ill have to work around
Old Feb 25, 2006 | 11:58 AM
scuc's Avatar
B8 S4
Wow, this is gonna be a pretty interesting project to follow. Good luck with everything.
Old Feb 25, 2006 | 07:00 PM
fsttyms1's Avatar
Also can some one direct me or show me the difference between teh standard header and the 6 speed header?
Old Feb 25, 2006 | 07:37 PM
The rear header has a bend in one of the pipes...
http://community.webshots.com/photo/...45208346EAvkeB
Fuzzy02cls found another source for 6spd headers (other then CT):
https://acurazine.com/forums/showthr...t=headers+bend
You can find more info searching for header bend... and headers bend
Old Feb 25, 2006 | 07:39 PM
I really wish that the DC sport headers would have been made for the 6spd...
https://acurazine.com/forums/showthread.php?t=178101 (notice there is no bend).
The auto headers w/o the bend don't fit the 6spd, but the 6spd headers w/ the bend WILL fit the auto...
edit: Kris, it snowed today, so I didn't get a chance to take pics... I'll try to do it soon... I need to crawl under my car anyways to check the RMS (rear main seal)... Going in for the 45K service soon, and the warranty runs out at 50K... Gotta make sure I don't have the RMS problem (J series issue, I think there is a TSB on the accord for it).
Old Feb 25, 2006 | 07:44 PM
Hey Brett, I see you lurking... Please correct me if I'm wrong about the header stuff...
You know that us "still stock" guys don't know anything
Old Feb 25, 2006 | 08:02 PM
fsttyms1's Avatar
Hey thanks for the header info. thats exactly what i wanted to know.
Old Feb 25, 2006 | 08:07 PM
mclarenf3387's Avatar
Your spot on. The rear header has to have that bend due to a shock on the rear engine mount on the 6 speeds.
Old Feb 26, 2006 | 05:21 PM
fsttyms1's Avatar
Here is a link to some progress pics.
https://acurazine.com/forums/technology-16/anybody-have-sony-t616-132270/
Old Feb 26, 2006 | 05:43 PM
Kris, the difference in weight between the CLS auto and 6spd is only 64 lbs...
3510 vs. 3446
Old Feb 26, 2006 | 05:59 PM
fsttyms1's Avatar
hum. i read awhile back that the tranny weighed alot less. Oh well either way its going to weigh less than the auto pig.
Old Feb 26, 2006 | 06:14 PM
ChucksCL-S's Avatar
Well Kris all I can say is that you're not afraid to attack big jobs. Keep us posted!
Old Feb 26, 2006 | 06:22 PM
ChucksCL-S's Avatar
Well Kris
I guess your 200K miles timing belt isn't a worry any more!
Old Feb 26, 2006 | 06:26 PM
Maybe the tranny weighs 150 less, but with the added extras (clutch pedal, extra motor mount, etc) it makes up for the differences in the overall weights
Yeah, the timing belt might need changing too Kris, while you've got the motor out
Old Feb 26, 2006 | 06:28 PM
ChucksCL-S's Avatar
Kris how did you come across the donor car? What was wrong with it?
Old Feb 26, 2006 | 07:28 PM
fsttyms1's Avatar
Yea i guess i wont have to worry about changing the timing belt om my engine any more, but atleast people know that it can make it to 200k. With the new engine (52k) ill probably change teh timing belt while the engine is out.
I just started searching for the tranny and found a place that had one.
Old Feb 26, 2006 | 07:37 PM
Chemmech's Avatar
Good luck on your ambitious project .
Old Feb 26, 2006 | 07:45 PM
fsttyms1's Avatar
Any one know what the different style mounts are for (like why do they have the shock style)?
Old Feb 27, 2006 | 02:46 PM
fsttyms1's Avatar
Got the manual today, packing invoice says 97 lbs. I was able to pick it up with 1 hand. you cant even begin to lift the auto with even 2. Id seriously say there is a 150 lb difference
Old Feb 27, 2006 | 03:37 PM
Interesting... I'm wondering if my car is lighter then Acura say's it is... I got those weights out of the acura brochure, but who knows how accurate they are...
Old Feb 27, 2006 | 03:42 PM
fsttyms1's Avatar
Im going to try to get my hands on a buig hanging scale to weigh the 2. There arent any parts that the manual has that would make up weight that the auto doesnt (like shift cables ect..)
Old Feb 27, 2006 | 03:47 PM
The only things I can think off is the clutch pedal setup and the extra motor mount... Not sure what else they could have added weightwise...
Old Feb 27, 2006 | 03:49 PM
fsttyms1's Avatar
is the header different because of the different rear mount? I cant see any reason not to use the TL mount i have and not need a different manifold
Ive got the 2 lined up and there is no clearance issue
Old Feb 27, 2006 | 03:55 PM
Maybe Brett will chime in....
I always thought the 'extra' mount was to act as sort of a torque strap... a manual car will have it's engine torqued around a bit more then an auto... Maybe the clearance isn't needed at rest, but only went the clutch is being dumped
Old Feb 27, 2006 | 03:56 PM
fsttyms1's Avatar
Ok. I wondered what the shock style mounts were for, or if needed.
Old Mar 16, 2006 | 03:21 PM
fsttyms1's Avatar
Hey guys im going to be doing a little work this weekend on it, and would really appreaciate a few pics (to take some guess work out) Could you post a few pics of the clutch pedal and where its mounted, and possibly if you can where it and the clutch master cyl are located in the engine compartment so i can get started mounting some of that stuff
Kris
Old Mar 16, 2006 | 10:09 PM
VeeralS05's Avatar
I NEED MONEY!
wow this is a hot project... can you do mine next haha jp!
