lock noise
Old Jan 24, 2003 | 10:59 AM
sidemarker's Avatar
lock noise
you know that small chime noise when you press the lock on the keyless entry. well were is it located becuase my cls does not make that noise anymore?
sidemarker
Old Jan 24, 2003 | 11:10 AM
CL P Diddy's Avatar
yeah,yeah,uh,huh,wh,what
you have to press the button twice to get the chime. So if you're in the hood, remember 2 times for the thugs
Old Jan 28, 2003 | 09:44 PM
sidemarker's Avatar
yeah but my problem is that it dosent make that noise anymore...
sidemarker
Old Jan 29, 2003 | 03:07 AM
KavexTrax's Avatar
master of the obvious,
sidemarker, do your light signals still flash though?
Old Jan 29, 2003 | 08:45 AM
JRock's Avatar
Old timer
I'm curious where the chime comes from as well. Someone with a HELMS help us out?
Old Jan 29, 2003 | 10:00 AM
Shawn S's Avatar
The “beep” speaker is under one of the front fenders.
I can’t remember if it’s the drivers or passengers side.
The HELM is at home.
I’ll check tonight if I remember unless someone else beats me to it.
Shawn S
Old Jan 29, 2003 | 10:26 AM
Scooter's Avatar
'Cooter
u know how the car WON'T chime if the hood is open???? maybe it's possible the hood is like half opened or something...how bout popping it open and closing it, see what happens
maybe the wiring to the speaker shorted out
Old Jan 29, 2003 | 10:39 AM
gto2050's Avatar
Someday pigs WILL fly!
Or the trunk.
Old Jan 29, 2003 | 10:41 AM
JRock's Avatar
Old timer
Yes, that's the car locking the doors but not setting the alarm since it would automatically start going off since it would sense the open trunk/hood.
Old Jan 29, 2003 | 07:05 PM
Shawn S's Avatar
I was correct, it’s behind the inner fender liner on the passengers side.
It’s held on with two screws.
It’s connected with a 2-conductor plug.
It says to test the buzzer, apply battery power to the No. 2 terminal and ground to the No. 1 terminal.
I hope this helps.
Shawn S
Old Jan 29, 2003 | 07:36 PM
SiGGy's Avatar
Moderator Alumnus
I bet one of the alarm sensors is malfunctioning for some reason or another trunk, hood, doors... Does the display on the dash show anything ajar?
Old Jan 29, 2003 | 08:07 PM
sidemarker's Avatar
i believe you are on to something! ever since my accident the hood does not close all the way so it is possible that this is the problem! my car should be ready friday so ill see if it works
sidemarker
Old Jan 29, 2003 | 08:09 PM
sidemarker's Avatar
I hope this helps.
Shawn S
thanks shawn hopefully its because the hood was not latched properly. but even if its a malfunctioning thing it dosent look to hard to replace and will probably be covered under warranty
sidemarker
Old Jan 29, 2003 | 09:06 PM
Zootking's Avatar
shooting for 1200+rwhp
im curious why it doesnt beep when you unlock it.....i kind of like the beep sound....i guess i could get an aftermarket alarm, but then again it doesnt bother me that much
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
