A little help regarding dealer suggested repairs...
Greetings...
Please bear with me as I don't know too much about cars.
I just got my 2001 CL-S back from it's 45000 service ($350! I thought that was a little steep, but that's another story) and had a question based on what they suggested I repair. Here is the text from the receipt I received:
"Techinician strongly recommends replacing both front knuckles and wheel bearings at this time because the front lower ball joints are worn excessively causing an unsafe condition."
They quoted me around $950 for parts and another $450ish for labor.
Is it me or does that seem like a whole lot of $$? Additionally, would I notice if I were having those problems? The car seems to be running well IMHO and I would think that if the lower ball joints were "excessively worn" I would notice somehow. I told them not to fix it for now and decided I should do a little research before forking over $1400.
Anyhow, thanks in advance.
mmarra
mmarra
My advice is to get a second opinion at a high quality independent repair shop. You might see the bill cut in half by the repair shop if the work does indeed need to be done.
ex 6 Speed owner :(
Seems strange to me that the ball joints would go out after only 45k miles. My Accord with 237k miles is still running fine. Absolutely get a second opinion and if needed definitely check about warranty, unless you're past the 5 year mark.
its a scam, knuckles usually never go bad, its usually just a lower ball joint by itself which is like $40, and about $100 to install it.
I had my lower ball joint replaced for $150 including parts and labor.
get it done somewhere else....
saberlove
03-11-2021 09:29 AM
Inspire08
10-30-2015 04:00 PM
