LIPPSTUH IS JERKING! 6-Speed
Old 09-23-2007, 01:29 PM
Unregistered user
LIPPSTUH's Avatar
Exclamation LIPPSTUH IS JERKING! 6-Speed
Okay, i've noticed a small jerk a week ago, but nothing to be alarmed about. i just kept my "eyes" out for any site of problems. today, i was crusing at 2300 rpm, gassing it about 8%, i wanted to speed up, gassed it at 75% and there was a 1 second lag, then it jerked like if the clutch didn't catch...
she's a 6 speed. is it my clutch? i have 35k on the car, oem clutch.
Old 09-23-2007, 03:11 PM
TQ > MPG
Joe5.0's Avatar
Nah, there is a hesitation that the 6 speeds have if you are at part throttle. It usally happens to mine if its not completely warmed up.
The clutch
Old 09-23-2007, 04:17 PM
srehmat02's Avatar
Mine hesitates when I go WOT in 2nd, but I think thats my clutch slipping
Old 09-23-2007, 04:52 PM
Unregistered user
LIPPSTUH's Avatar
this has been recent.. it was pretty noticible. even my little sister who is 12 said my car is driving weird....
i'm not sure what the definition of slipping is.. but to me it felt like a slip... gassed it, hesitated, clutch caught back on... btw i was in the same gear hence i didn shift when this happened if that makes sense.
Old 09-23-2007, 05:59 PM
B A N N E D
M.J.H.'s Avatar
If so that's pretty crazy because I have 104K miles on my stock clutch and it's just BARELY slipping, really feels pretty damn strong with the CDD removed.
Old 09-23-2007, 10:52 PM
fuzzy02CLS's Avatar
It's only a slip if your RPM's were climbing & you were not going anywhere.
I've gotten the same thing on occasion on my 2 6mt's. No explanation.
Old 09-24-2007, 12:08 AM
Unregistered user
LIPPSTUH's Avatar
okay, hopefully its nothing...
Old 09-24-2007, 08:43 AM
dankness's Avatar
what does it mean if my 5AT does this on occaision?
Old 09-24-2007, 10:13 AM
Unregistered user
LIPPSTUH's Avatar
AT's are usually slow on throatle response because it has to shift... BUT if it you're in 5th gear traveling steadily at 70mph or something, and it downshifts to 2nd gear then you have tranny problems.
Old 09-24-2007, 10:21 AM
distortedolskool's Avatar
it means your number is about to be called and you will soon be posting in the "my transmission took a crap" thread. could just be a normal hiccup. hell i had a 95 f150 that wouldn't shift if i was hard on the throttle. did that for 5 years and the tranny was still going.
Old 09-24-2007, 11:02 AM
B A N N E D
New Image's Avatar
there is an explanation, and its misfiring. thats what ive been going thru and trying to figure out a solution
Old 09-24-2007, 11:23 AM
2014 TL SH-AWD Advance
03sixer's Avatar
I have a 6MT as well, and there have been a couple threads about this. Everytime my car gets to operating temperature, there is a hesitation...almost as if the car loses power for a half a second. Not clutch related obviously. As for slipping, I have almost 70K miles and it has never slipped. Fortunately, I know what a slipping clutch feels like and it's just as someone above described. If it's slipping just a little bit, you will feel it (1) Not pull as hard, (2) see your RPMs climb at a much faster ratio then your speed, and when you let off the gas they will drop back down to where they're supposed to be at the given speed in whatever gear you're in.
Old 09-24-2007, 12:59 PM
Unregistered user
LIPPSTUH's Avatar
so is this normal or a problem? i was thinking misfiring would be one of the potential explanation.
thanks for all the responses.. drove the car briefly yesterday, didn't feel it again, maybe it's a 1 time thing.
Old 09-24-2007, 02:57 PM
fuzzy02CLS's Avatar
Misfires would trigger check engine lights, or codes. So unless you have those they are not misfires.
Old 09-24-2007, 03:42 PM
srehmat02's Avatar
Actually, now that I think about it.. I had my check engine light flashing a couple times while I was driving it hard, so it is possible mine could be misfires. I will check on my coil packs and plugs later today.
Old 09-24-2007, 10:15 PM
fuzzy02CLS's Avatar
That is normal. When you break traction & the car can't grip the ECU will see a misfire & throw a light,(flashing) but it's not really a misfire. The lack of traction fools the ECU.
Old 09-27-2007, 04:43 AM
Unregistered user
LIPPSTUH's Avatar
happened 3 times tonight... constantly at 2400 rpm on 5th gear. stepped on it and it jerked... like it didn't catch right... a few minutes later i see the check engine light light up... then 15 minutes later it's gone...
Old 09-27-2007, 08:59 AM
fuzzy02CLS's Avatar
Scan it. Maybe a code is stored.
Clutches don't generate CE lights, so sounds like a dirty or bad sensor to me. Or a coil, or spark plug.
Old 09-27-2007, 10:34 AM
Unregistered user
LIPPSTUH's Avatar
okay thanks, i'll have it checked and report back to you guys. probably bringing it to a shop
Old 09-27-2007, 10:43 AM
B A N N E D
New Image's Avatar
i get the flashing cel under WOT sometimes also. compared to always on cel.
it was the coils and plugs in my case.
Old 10-08-2007, 07:06 PM
cuonglogan's Avatar
clucth
Mike Pilipenko
03-26-2024 09:21 PM
drone619
01-26-2016 07:09 PM
DidiBob
4G TL Problems & Fixes
09-23-2015 08:14 PM
Quick Reply: LIPPSTUH IS JERKING! 6-Speed
