Legitimate question reqarding jack stands
6SPDCLS
Someone please help answer this question:
I have purchased a 4 ton hydraulic jack AND a pair of jack stands. Now the question is how do you supposedly jack the car up to a fair height in order to place the jack stands underneath the each of the two side jack points under each of the sides? I know in the car manual there are four (4) total points in which you would use the car jack but if I use the 4 ton jack, there is no point to jack up the car!
When I had to install the comptech sways, I had to use a brick to jack the car up. I do remember seeing the jack points in the front and rear of the car (underside) but I don't have that manual with me. It's not in the consumer manual but it's in the technical manual (the one you buy).
Anyone have that diagram of where to place jack to lift car? I couldn't find it in the useful topic and search.
Thanks!
Thanks!
What I have seen before on other cars is find a spot in the front of the car so you can jack it up with out useing the jack spots...that way once the car is up you can put the stands in place. Dont quote me on this because I am not sure if it is the right way...but I have seen it done with out problems on other cars.
I would put the jack next to the jack point of the car and bring the car up and put the stand under the jack point. This is what we did with my brother's Passat. This is probably the safest way to go about it. I wouldn't know where the jack point is under the engine and it would very risky if you made a mistake
Originally posted by sidemarker
front tow hooks is the perfect place to jack the car up
Do not jack the car up there.
Thase are not designed to hold the car.
The REAR one YES, the FRONT ones NO !!!
Shawn S
PS.... Stand by. I'll find some photos for you
There YA go.
Use the REAR tow hook to jack the back of the car and put your stands in place at the factory spot.
For the FRONT, use the spot just forward of the engine directly in the middle of the car and then place the stands in the factory lift positions.
Shawn S
Shawn S
Administrator Alumnus
Would this be a good approach for installing sway bars? I'm assuming next weekend will be the time I put them in. Are there clearance issues that I'll need jacks or something similar?
6SPDCLS
Originally posted by Shawn S
There YA go.
Shawn S
There YA go.
Shawn S
For the rear, I didn't know how high to jack up since I am new to the 4 ton jack, I didn't know if it can extend as vertical as yours (almost 90 degrees it seems). As for the front, I'll look underneath to see if I can find that point to use the jack. I saw it in the tech manual but I forgot all about it.
Thanks! you the shet!
navtool.com
31
11-16-2015 08:30 PM
SUPRMN84
10-07-2015 09:46 PM
navtool.com
09-25-2015 05:15 PM
