Legend calipers
Legend calipers
I know this was covered before but im lazy.... I was wondering were to get the 2 piston Legend calipers for our cars. I'd perfer getting new ones but used would suffice as long as they are in good condition. I was searching on Ebay but only pulled up the single piston ones. Is there an OEM online ordering place that seels the whole caliper as like a kit or something? Any help would be nice.
thanks
thanks
got them remanufactured from napa for $55 each plus $66 core charge each. just ask for 1995 Legend LS coupe front calipers.... then take back your single-piston calipers back for the core charge refund. they won't even open the box.
installation is simple: just swap left and right calipers and use all of the old CL mounting hardware.
https://acurazine.com/forums/ramblings-12/test-181612/
Originally Posted by gaping46and2
Do you need to bleed the brake lines after changing the calipers? I remember reading something about crimping the brake lines before removing them or something like that.
thanks fellas for all the info, just one last question. will the pads on my CL brakes fit the lengend calipers or would i need to order a new size and if so what size.
thanks
thanks
thanks
thanks
The caliper size is EXACTLY the same so the pads can be inter changed. The only difference is that there are 2 pistons in the Legend or NSX calipers vs 1 large piston in the CL or TL.
I had NSX ones on my CL. It is definately a good upgrade. Enjoy.
Originally Posted by 972xghost
damn i didnt know Legend calipers would be an upgrade compared to stock 2nd Gen CL's. i know its a tremendous upgrade for us 1st Genners.
B A N N E D
Type II came out in 93, the L has a single piston, you get to get the ones for the LS ver, to be on the safe side make sure you ask for a 95 LS
Damn I wish I wouldof taken my calipers off when I got rid of her
Good luck with that
SOLD: 03 SSM CLS Auto
Good luck with that
B A N N E D
Loaded, semi-loaded, or Unloaded? Also, any preferences with remanufacturers?
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
