legend caliper question
Originally Posted by cltypeSLOW
why is the legend caliper better than the nsx one? i thought they were the same?
The 93-95 Legend LS coupe calipers have the largest pistons, bigger than the NSX calipers.
Yeah, I'm in the process of getting my hands on a pair of calipers myself.
Absolutely! I know I'm going to be in the Houston area on turkey day. Hit me up on AIM whenever. You still wanting to get those LEDs too?
schweet. thats the ones i have. do you still want that suspension over thanksgiving break?
Originally Posted by RaviNJCLs
I was going to powder coat them and do the rears as well, but it was going to be too much work.
The Legend caliper has 42 mm and 38 mm pistons. The NSX caliper has 34 mm and 36 mm pistons.
Just got my calipers installed and had a quick question. Do the stock CL calipers have a retaining clip on the top of the caliper like the Legend does? Number 18:
When I installed the clip it rubbed on the outter edge of the rotor, make a gosh awful noise. I was trying to find a part number for the CL caliper, but couldn't find anything.
Do not install those clips. I think I mentioned that in my thread when I installed my calipers. I had the same problem. I took them off....problem gone.
It's certainly better than the stock setup, although I was expecting a much more drastic outcome. Hopefully I'll only have to change pads every 30k+ miles and not have to deal with warped rotors anymore.
Originally Posted by Sly Raskal
^^ depending on if you are hard on your brakes.
Did you ever have problem with warping on your rotoras with your NSX calipers? I changed out the whole front brake system with rotora rotors, ss lines, ebc pads and the legend calipers.
Why is the CL prone to warping? I've had the car for two years now and haven't had a problem yet. The car did come with cross drilled rotors, don't know who made them. I notice a humming noise if I go on the brakes pretty hard as the car stops, but I read somewhere that noise is normal? I'm hoping to do my caliper swap at the end of the month.
The stock rotors and pads suck, and the car weighs 3500lbs.
Question for those who have done the Legend/NSX caliper upgrade. I was wondering if you guys noticed the pedal is softer at all because the master cylinder is pushing more fluid to the caliper, volume of the single piston vs the volume of 2 pistons?
Another concern was braking when there is little pad material left, as someone brought up in another thread.
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
