LED Lisence Plate Light
Originally Posted by HondaVtec21
Is anyone else having a problem with their festoon bulb for the dome light??? I replaced mine the other day, and i noticed that when the light is turned on, it flickers a little bit. So I tapped on the plastic casing and the light completely shut off and wouldnt go back on. I took it apart and found the bulb wasnt touching the metal clips inside. For some reason the LED bulb is smaller and shorter than the OEM one, and does not stay in place securely. Does anyone else have the same problem as me, or know what I'm talking about. . .?
4410 LED Festoon bulb 44x10mm (1.732 inches long)12 VDC Festoon Base Bulb with 9 LEDS, and I've never had a problem with it being loose or flickering.
Originally Posted by gaping46and2
This is the bulb I got from superbrightleds.com:
Sorry, but ever since I joined AZine I have been nickel and diming myself to death! I hate you all and love you all at the same time... thanks for the find and the advice, but damn this mod bug I never thought I'd get! LOL
^^^ Post pics of LED tails. Has anyone done their glove compartment light? If so how hard is it to get to the light? Im thinking about it but just wanna see what it takes. I get alot of compliments on the dome light when I unlock the car, extremely good cheap mod that everyone should do.
Thanks guys. I promise it's not photoshopped! It's just at night with a tripod and with my Canon in night mode. It looks great though I'm not sure how I feel about the light being reflected onto the ground. I might try to mask off part of the light housing or something. Even if it doesn't work I'm still very happy with the results and can't beat it for $10! Oh and the fact it only took 5 minutes to install.
Originally Posted by mytran
I found the single led bulb not bright enough so I ordered this:
from superbrightleds. Costs $14.95 but its as bright as the Lexus ones.
from superbrightleds. Costs $14.95 but its as bright as the Lexus ones.The 7443 LEDs is what you wanted for the easy mod.
Originally Posted by GreenMachine
And where the hell do you plan on putting that? Unless you plan on opening up the taillamp housing.
Originally Posted by Presto
What is that a spotlight? What kind of spot does that leave on the pavement under??? Lets get some pics of that bad boy
SI wasn't listening.
Originally Posted by bigmark89
i would think that water would get into that thats why there is a cover on it so water wont seep in those things are def. gonna get wet
Originally Posted by LIPPSTUH
is that blue on supertroopers? any suggestions on which type to use on the tail lights? i also want to replace the signal with red leds
DAMN!!! Thats pimp
what kind of LED did you use??? Thats sooo sexy
what kind of LED did you use??? Thats sooo sexyhttp://cgi.ebay.com/ebaymotors/2-Bul...QQcmdZViewItem
Here are some pics of the map lights, just got them and they make it look like daylight inside
From the back of the car
From right outside the drivers window
Here are the bulbs
They look awesome!
Here are the bulbs
They look awesome!
good luck with superbrightleds. i've had nothing but shit bulbs from them, they don't even last 6 months. I have them in my license plate bulbs, had them in my dash. The only thing that hasn't failed me was the single led's, cuz i soldered those in my climate control and all those switches.
hehee...I have LED brake lights
...more LEDs to come
Originally Posted by EdsonDJ
I just installed LEDs on my brake lights too. Although, the "Brake Lamp" indicator went on. I installed load resistors on them also, but that didn't get rid of the indicator. I don't think I hooked up the wires right. How about yours?
I just bought the load indicators so I'll let you know...You need one indicator for each LED bulb. It has to be powered through the 12v power wire. I suggest getting someone posting the wire diagram for the brake lights (like me) or test the wires yourself. All you need to do is buy a 12v indicator and check which wire is hot (where you plug the bulb in). I have 3 more LEDs coming; rear blinkers and the lonely 3rd brake light I haven't used since I bought the car.
Has anyone used autolumination.com? Seems like they carry a larger selection than superbrightleds.
i think imma buy all my LEDs from ebay... anything bad with that?
also, i've seen 1 cl with red turn signals (03 taillights) and it looked nicer than amber turn signals. shall i go with red?
