LED Cluster
Old Dec 3, 2009 | 05:41 PM
  #41
friesm2000's Avatar
B A N N E D
Originally Posted by MrFluffy
Yeah I have to go in and fix it a little
That was full when I started
at least you recognize it, but otherwise very
the whole bottle would of been gone with me
also are you trying to be part of high society with that tray and stuff there
also what is that in your coffe cup egg nog or something (does not look like coffee to me)
Old Dec 3, 2009 | 05:55 PM
  #42
MrFluffy's Avatar
To many cars in my garage
Its all my wifes doing ( she actually got pissed that I didnt move the table cloth and all the other stuff but I have a bit of a one track mind)
The coffee is the one cup coffee maker coffee its really good
Old Dec 3, 2009 | 06:18 PM
  #43
friesm2000's Avatar
B A N N E D
and the wife is the cause of all your problems (hitting god damn curbs and taking out the alignment:angryfire)
and having the booze right there makes it more convinent for those tuff moments,
and the tablecloth makes it easier for you to clean up; pick it up, go outside (or over an trash if you must), shake, go back inside, toss the table cloth back over, ALL DONE
so is it the instant , i don't drink
Old Dec 3, 2009 | 06:46 PM
  #44
Rajca's Avatar
wham bam thank you ma'am
im gonna be trying this on my cl also, but plan to do a few diff things.
Old Dec 3, 2009 | 07:35 PM
  #45
MrFluffy's Avatar
Mine was very painless and easy
friesm I will be sure to tell my wife that
Im sure she will see that I was looking out for her best Interests
Its no instant but it just makes one cup
I am starting stage two of my cluster project tonight will update when finished
Old Dec 3, 2009 | 08:19 PM
  #46
evan03CL's Avatar
Wait...I just blacked out
looking great so far!!
Old Dec 3, 2009 | 08:33 PM
  #47
civicdrivr's Avatar
The top of the speedo needs some work, its got a hotspot.
Otherwise, very nice.
Old Dec 3, 2009 | 10:09 PM
  #48
distortedolskool's Avatar
hot spots can be more noticeable in photos due to the low camera shutter speed. however to the naked eye one can't see them. i do think the tach needs some adjusting. nice job!
Old Dec 4, 2009 | 12:34 AM
  #49
MrFluffy's Avatar
This is true I spent the last couple of hours fixing it all and then took these pics was like what the hell
I fixed It all up that tach 0 was a bitch
So I also finished stage 2 I did blue as you know and to add a little something extra I did Purple except purple was not as bright as blue but still brighter than stock. now I can flip a switch and my dash and other ambient lighting goes from Blue to purple I also have red but not in the dash
So here they are
Blue
And purple
Hope you like it
Old Dec 4, 2009 | 02:39 PM
  #50
friesm2000's Avatar
B A N N E D
SWEET.... with the color changing
Old Dec 4, 2009 | 02:42 PM
  #51
friesm2000's Avatar
B A N N E D
also something like this will let you get even more colors in there (just alot more wiring though)
http://www.superbrightleds.com/cgi-b...iColor_LED.htm
Old Dec 4, 2009 | 02:51 PM
  #52
friesm2000's Avatar
B A N N E D
and with those you can get any color you want then, just by making each color dimmable by itself
Old Dec 4, 2009 | 02:57 PM
  #53
MrFluffy's Avatar
Definitly alot of wiring but alot of complex sodering as well but thanks for the link I might swap mine out for those next spring
Old Dec 4, 2009 | 03:29 PM
  #54
friesm2000's Avatar
B A N N E D
alot of wiring, kinda just need one more power supply wire (since you already proably got two [just need 3] power wires for multi color) with a common ground,
complex soldering, all soldering is basically the same but yeah quite a bit more and repetitive
but yeah the biggest thing is the wiring inside the gauge cluster with not allowing the wires to short against each other being kinda confined in there, but be easier to mount the actual LEDs, cause you only got to mount one type of LED
also np for the link
Old Dec 4, 2009 | 04:32 PM
  #55
MrFluffy's Avatar
It would defintly be easier than the way I did mine but the way they are aimed and how the led leads bend over aech other would be a headache to aim but easier than my way
Old Dec 4, 2009 | 05:42 PM
  #56
any pics of the LED setup behind the gauges?
Old Dec 4, 2009 | 07:23 PM
  #57
MrFluffy's Avatar
I have one pic but its just the one set of leds but I drove it today and I hate the purple its about 1/5 the intensity of the blue so I may be swithing to red sooner than later
And as soon as I got everything place right I didnt want to mess with it I just wanted to seal it up and be done with it
Alhought I saw PHEES and I didnt not use resistors I ran them in series of four ( as per the specs on my leds)
Old Dec 4, 2009 | 07:32 PM
  #58
friesm2000's Avatar
B A N N E D
mod took too long and were too impatient lmao (i am the same way sometimes)
in series will work perfectly fine , but those leds i sent you the link to will more then likely have to be wired in parallel, but you should just have to use one big resister at the power supply side to drop down to the necessary voltage (but be best to look for ones with a higher voltage rating for the most efficient power comsumption)
Old Dec 4, 2009 | 07:35 PM
  #59
MrFluffy's Avatar
How much are those anyways
Old Dec 4, 2009 | 07:48 PM
  #60
MrFluffy's Avatar
I just found the price on those 1.59 an led thats expensive im going to look on ebay
Old Dec 4, 2009 | 07:49 PM
  #61
friesm2000's Avatar
B A N N E D
IDK, i just YAHOOed "tri color LEDs", anyways they might even be too big, it was like the first link i clicked on and figured it had some good pictures on it
Old Dec 4, 2009 | 07:52 PM
  #62
MrFluffy's Avatar
I found some I may buy these next week http://cgi.ebay.com/100-5mm-tri-colo...item1c09f4dbe7
Old Dec 4, 2009 | 08:05 PM
  #63
friesm2000's Avatar
B A N N E D
i might have to be a then
btw: shipping seems outrageous, but otherwise a good deal
and you gotta like how they are from china
Old Dec 4, 2009 | 08:25 PM
  #64
MrFluffy's Avatar
They were Invented in china! I only ordered leds from the US once and half of them didnt work ! $28 for 10 leds its double what I payed for 100 leds but they are 3 in 1 so its a pretty good deal !
Old Dec 4, 2009 | 09:53 PM
  #65
friesm2000's Avatar
B A N N E D
yeah those actualy don't seem that expensive at $0.28 each which breaks to like 9 cents per color
CL-S progression 01
Jan 26, 2016 04:15 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
Retep Nitciaj
1G RL (1996-2004)
Oct 6, 2015 01:36 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
eastcoastguy
Sep 23, 2015 06:29 AM
