Larger Rims
Old Jan 26, 2001 | 07:27 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
Larger Rims
I just wanted to know if you get larger rims...will your ABS, Traction Control, and yaw control get knocked out of whack. I ask this question because all of the above are dependent on wheel speed, size, and weight. If you swap out the rims, the diameter might be the same, but the lighter weight of the wheels and increased revolution speed would throw it out of whack right?
2001 Cl-S Black on Black with Navigation
Weapon-R Dragon Filter
Old Jan 26, 2001 | 07:57 PM
[DWI]'s Avatar
If that is the case I'll just replace my stock rim.
Old Jan 26, 2001 | 08:00 PM
I just wanted hear the thoughts of the techies....because I really love to slap on some bigger rims...I miss the grip of +2 rims and tires....
Old Jan 26, 2001 | 08:15 PM
scalbert's Avatar
The ABS and TCS (or VSA) don't work off of the actually speed of each in most cases, but rather a difference between all the wheels.
The use a frequency measurent from inductive sensors. If one wheel has a significantly higher frequency that the other three, something is up and it take action.
However, if you do go to an overall size difference your speedo will be off and will also affect the odometer.
Old Jan 26, 2001 | 08:21 PM
DDT-TypeS's Avatar
6SPDCLS
<font face="Verdana, Arial" size="2">Originally posted by scalbert:
</font>
Usually you'll have to upsize your tire in this way in order not to alter the speedometer:
For every one inch (1") increase in rim size you'll have to:
Increase Width by 10mm
Decrease Tire Ratio by 10%
So in our CLS case, it would be:
(stock) 215/50R17
(18" rims) 235/40R18
But you'll have to find out if the tire manufacturer makes the size of the tires.
08KBP_VA
Oct 22, 2019 01:55 PM
kev87a
Nov 2, 2015 07:40 AM
Gout
Nov 2, 2015 12:22 AM
kev87a
Oct 18, 2015 02:03 AM
dirleton
20
Oct 16, 2015 01:48 PM
