Ksport BBK
Don't Mess With Texas
Ksport BBK
anyone know the scoop on this product?
they dont make a direct line for the CL, but i was wondering if anyone knew if the kit for the 98-02 accord v6 would work. it seems like a realy nice kit seeing as how its an 8 piston setup. let me know bbk experts!
http://www.ksportusa.com/products/brakekit.html
Originally Posted by pits200
Don't forget, you would probably need a new master cylinder for that bad boy. Its a monster.
anyone else have any input on this? would i really need a new master cylinder?
Originally Posted by Titand19
unless you are autocrossing or at the track I doubt 8 pistons would benefit you anymore than 4. And for 2g's I'd much rather get a set of brembos.
as for the price, i can get them for about the price as the rotora kit. so that is what im comparing them to.
ASM I.S. Design FTW.
Originally Posted by cltypeSLOW
whys that? just for the name?
throw your in brian i see your watching
I'm Cool
Originally Posted by brianlin87
that's a good point - but then again upgrading the rear brakes should be fun.
Thats true, with 8 pistons, what the heck, is each pot the size of a nickle.
That's Racist
Originally Posted by mclarenf3387
Probably closer to the size of dimes. The Brembo calipers seem to be the biggest calipers for this car and those use a 40mm and 36mm piston on each side. The pistons on these Ksports must be tiny to fit 8 onto those calipers, and if they are that small, it will give you no advantage over a 4 piston set-up with pistons of equal total size (equal area of all pistons). The only advantage I see to these is being different and being able to say you have 8 piston brakes.
That's Racist
Originally Posted by CleanCL
a guy on the lexus forums said he saw them in person and their not very impressive.
Originally Posted by Time For Sleeep
what would be unimpressive about them visually detectable?
both rotors are 330mm. ~13inch pistons are bigger but less of them. so the braking force isnt spread out as much. thats why the OEMs warp so bad cause its focused on one spot. i was thinking these would be better even if the pistons are smaller and the caliper is the same size....it would be spreading out the braking power more evenly accross the pad. know what i mean? correct me if im wrong
mugen_kid
11-13-2015 10:38 PM
handsom-hustla
11-13-2015 05:04 PM
