K&N How to install?
Old May 19, 2001 | 01:51 PM
Al Uminum's Avatar
K&N How to install?
Guys
Which way does the air filter go in?
With the filtering element flat side facing up or facing down?
Thank you
Rob
"01" CL Type-S
White\Black
Comptech Springs
Comptech Sways
17x7.5 BBS RX Rims
Navigation System
Burlwood Shifter
Guards+Fenderwell Trim
PIAA16969
Smokers Package
My Car
Old May 19, 2001 | 02:37 PM
SinnedTL's Avatar
Ain't No Other...
<font face="Verdana, Arial" size="2">Originally posted by Al Uminum:
Guys
Thank you
Rob
</font>
the flat side facing the top
2000 Acura 3.2TL, Satin Silver, OEM spoiler, H&R OE springs, Piaa 1700x fogs, K&N filter, 17"x7.5 ATP S5 wheels,215/50/17 Pirelli P7000, Inspire Fog Switch, Polarg M-12 blinkers.
Old May 19, 2001 | 02:50 PM
gavriil's Avatar
Moderator Alumnus
Does the K&N make any difference? How much is it and where did you get it from guys?
Gabriel
CL Type S
Old May 19, 2001 | 03:23 PM
Al Uminum's Avatar
Flat side going up?!
I thought that would present less filtering surface to the incoming air so I put it in folded side up. Seems fine and with a little grease on the tabs I finally got it in.
I got mine from Ahmotors. Cost for filter is $48. Total was almost $55. High! The part number for the Type S is 33-2178.
"01" CL Type-S
White\Black
Comptech Springs
Comptech Sways
17x7.5 BBS RX Rims
Navigation System
Burlwood Shifter
PIAA16969
Smokers Package
My Car
Old May 20, 2001 | 12:04 AM
fast_daddy_car's Avatar
It should only fit in one way. The ridges/fins should go down, just like the stock filter.
I had no problems with the tabs, everything slide back together fine.
2001 Satin Silver CL Type S.
No Navi, PIAA 19169, Comptech Sways, Century Childseat, Mudguards.
Old May 20, 2001 | 04:10 AM
SilverKnight's Avatar
Retired. Not available.
</font>
Just curious ... if you have to pay $55 for a drop in filter? why not pay $100 for a CAI including a filter? well, it's actually a short ramp for Accord but it's a CAI in my car.
'01 Silver CL-S
Painted Mud Guard
Silver Aluminum Pedals
Kenwood Amp with 10in. Pioneer sub.
(modified) CAI.
My Car
Old May 20, 2001 | 04:38 AM
TakeFlight's Avatar
The proper way to put it in (because I just asked this question a few days ago and confirmed it with friends) is to put the flat side up and the protruding side facing down.
With that said, it will fit both ways. In fact, it is an easier fit when you put it in upside down. When you put it in the correct way (flat side up) it's a bitch and a half to get the cover back on because the seal of the K&N is a little taller and wider than the stock one. It makes it hard to get the tabs through the slots. I was able to do it without any grease or anything. The key is to do it on a severe angle with some firm pressure while pulling up on the slot with a finger or two. I didn't have to trim the filter or cut it any to fit the screws like others have mentioned.
WORD OF CAUTION: Closely examine the engine side of the filter (flat side) before you install it. Mine had an errant piece of the wire mesh stuck in there that would have been swallowed by the engine had I not examined it before I installed it.
2001 Acura 3.2 CL Type-S - San Marino Red / Parchment - #26519
non-nav - spoiler - wheel locks - splash guards - PIAA 19169s - K&N air filter (33-2178) - Zaino baby!
Pics of my car
Old May 20, 2001 | 03:29 PM
Al Uminum's Avatar
True enough I fit it in both ways. But it fits in easier (and correctly) flat side up which of course presents the taller filter element to where it should be. Down to the ground. Btw I found a handfull of leaves, feathers and other junk on the bottom side of the OEM filter. At least it worked but if I ever go with a real CAI ($100 heh heh...puleeze) I'd feel better getting the bypass. I mean for $50 how could you not want to rest easy thinking hydrolock?
"01" CL Type-S
White\Black
Comptech Springs
Comptech Sways
17x7.5 BBS RX Rims
K&N Dropin AF
Navigation System
Burlwood Shifter
PIAA16969
Smokers Package
My Car
Old May 20, 2001 | 08:48 PM
<font face="Verdana, Arial" size="2">Originally posted by SilverKnight:
</font>
Because of the extra outside noise the CAI produces. I bet filter life is also shorter.
bungln
Feb 20, 2019 08:47 PM
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
TxRzrBk
Sep 17, 2015 01:07 PM
Aleax
Sep 9, 2015 08:04 PM
DDTsx06
Sep 8, 2015 06:56 PM
