Just hit the legendary 147 mark tonight!
So I've had the car almost a year now and tonight was the night, I finally hit 147!!!!
I'm assuming it was 147 at least, the speedometer looked like it was 149 but I've read that the gas cutoff is at 147.
I certainly hope it was at the track. Do you know what would happen to you and your passengers and people in other cars if you wrecked going 150mph? You would be in a million pieces and destroy other innocent lives and there families. Im sorry but thats just absolutly stupid going 150 in a CL on a public road. Hopefully next time you get caught before you kill yourself
failhard.
^^ in public roads teeming with cars, i would agree.
however on an open road with no one around you for miles .. free game until a cop spots you. that way you're only putting yourself at risk, and you face the consequences alone .. although your friends and family will bite it hard if they find out your body pieces are scattered in some bushes somewhere.
07 tl-s in
congrats.when my baby was up to par, i tapped my 1g out at 140+.what a rush.no better feeleing than wot and open road......
best pic i got,tried to get a pic pinned but the no look point and shoot didn't work.at 140 it's hard to take a pic and stay alive in one piece at the same time.........
no one will ride and take the pic for me......
Next Car Coming Soon
Originally Posted by fuzzy02CLS
Oh please, enjoy life man, your only here once.
Dude
Nuts man, i'd be way too paranoid to do such a thing because, what if teh tranny just decides to slam it into 2nd gear while you're at it. Well for us autotragic guys
going that fast on a road that is not meant for it is just insane
I'm pretty sure the fuel doesnt cut off at 147.... A friend of mine has a CL-S 6mt just like mine and I was with him once when he got 155 on interstate 75 here in GA. He has basic bolt ons, but not anything that would change the air/fuel systems.
Moderator Alumnus
Yeah...I've only done 120...my avatar speaks for itself.
-That was fast enough when everything was stock. The car felt like it was floating.
07 tl-s in
Originally Posted by o1s
then he didn't make it to 155. there is no way to defeat the speed limiter on stock ecu.
1 Post
Originally Posted by subbuzz
won't goin downhill increase your mph and go past your car's "governed" speed?
Also, I don't htink the CLS6 is speed limited. only the auto's.
It was on a public road but was really late at night and I did a drive through first to make sure there were no cops then waited for a time where I was the only one on the road. I'm sure my fuel did cut off because when my needle was on the 150 I could hear it the engine letting off and coming back on when the governer kicked in.
The interesting thing is that I hit 147 in fourth gear, I didn't even need to use 5th
It sure was fun, HUGE adrenaline rush
If the road is clear of traffic, it's not that big of a deal... It's not like mbtslc does 150mph every day...
I was talking about tires with my brother last night and he reminded me of the story when he did about 140mph for about 15 miles on the highway and when he pulled off and stopped he said you could smell the tires because they were so hot ( S rated tires )...
I've set cruise control at 100mph for about an hour driving down to florida from MA... middle of the night (3am or so) driving down thru SC and GA back in my crazy younger days...
https://acurazine.com/forums/showthr...oretical+speed
Look down at scalberts post...
Originally Posted by GreenMonster
The 6spds are electronically limited to 149 mph (or so)... The auto's top out at 147 (or so).
I don't think it's a coincidence that the CL is outfitted with V rated tires which are rated for up to 149 mph
Originally Posted by mclarenf3387
Speedometers on cars are not entirely accurate and the faster you go, the more they can be off. The only sure way to know what speed your going is GPS or radar/laser.
a single antenna GPS will not give an accurate speed reading as they can only get you within an accuracy of about 150ft. The only truly accurate GPS reading comes from a 2 antenna system and that can get you to accuracy of 1.5cm or less and the antennas have to be a certain distance apart and require the use of a base station for a correction signal.
I was reading in this that speed thread and one of the things that I would tend to disagree with is the 6mt launching better than an auto. That is solely driver dependent and if you have 2 average drivers, and everthing is equal the guy with the auto will usually win...off the line...automatics (due to torque converters) have the ability to multiply the torque available by 2-4x the manual catches up quickly due to lighter weight and no slippage...
Also I believe that although the CL type S 6mt is rated at 260HP, it is acutally around 270+ based upon it's accelleration numbers.... 60lbs does not equate to almost .5 sec quicker run times
and if you're running anything other then the OEM tire on the car, the calibration on the speedometer is going to be off...
http://www.miata.net/garage/tirecalcold.html
MP90 uninstalled
all the Cls/TLs blocks are the same. there are a small hand full of parts you must change on the whole motor assembly like cam sprocket etc. to make it work for either trans.
I know that the engine is electronically limited at 147, does anybody know if that is based off the RPM's in 4th and 5th or exactly how it works, because my speedometer was definatly past 147, it looked like 149 or 150 before it kicked in
I think mine is a little off for this reason, I have with 225x40x18's which are just a hair smaller. That would make my speedometer show I'm going a little faster than I actually am.
Speed is determined by VSS and this is taken from output shaft on transmission
Saw 150 on the A60 Autobahn, '01 CLS
The fuel-cutoff does happen around 147, but I had a lot of momentum as I was accellerating on a downhill. After the fuel cut-off I still touched 150, but after that it was simply in and out of the fuel-cutoff.
The first thing I did (other than put gas in the car and put on my German plates) was to hit the autobahn and find the limiter. It got there in a hurry. I also ran from Wittlich Germany to the Frankfurt airport at an average speed of about 130. It does nothing for your mileage, I can tell you that. It's about a 90 minute drive at that speed and it took 3/4 of a tank!
ahhahha130mph for 90 mins = about 195 miles or 15.6mpg....not too bad
I guess it wasn't that bad...
Trivia - above about 85mph the windshield washer fluid pretty much blows right over the windshield.
Having driven the car on a few occasions at or close to the limiter, it's my opinion that it wouldn't go much above 150 even without the limiter. I saw that question asked in another thread ("how fast would it go?") and I think it's somewhere under 160 (stock) even without the limiter.
That's Racist
can't say that I agree with hittin' this kind of speed on public roads.
Clear road or not, you come up retardedly quick on anything around when going @ almost 150 mph. Coming up speed combined with the shitty single piston brakes on the CL's, it's just plain scary.
But as long as you're having fun.
