Just Bought OptionRacing Pulley
#121
Whats up with RDX owners?
You sure you're turning it the right way?
#123
I Blaze Up In
*UPDATE*
OK, so im working on the pulley right now and Im taking a little break to update you guys on the progress.
Everything is going smoothly, I took some good pics for you guys and im working on getting the CP Nut off. The 3/4" air gun that I was planning on using was broken by a student a few weeks ago when he dropped it and broke the piece that the air hose connects to. So Ive been trying to take off that nut and so far nothings worked and ive been trying to muster up the courage to do the starter method for the last 30minutes.
I WILL get that nut off sometime today and i'll do the diy writeup by tomorrow.
-Mark
-Mark
#124
*cough* blip the starter *cough*
#125
I Blaze Up In
OK It is finished!! It took me about an hour and I must say that I am now an avid supporter of the starter method. It took about 5 blips and that nut came right off. and after that reassembly was easy as pie.
Now for the bad news, my camera died halfway through the install right as I was about to take a picture of the starter method. So im gonna see if I can take my car back to the shop tomorrow and finish taking the pics of the reassembly.
Now for more good news. The pulley is fucking awesome! You feel the rpm's spike alot quicker in all gears. And when our cars hit 4th gear it feels like we ran into a brick wall, and the pulley helps with that. And because the rpms spike quicker, vtec comes up faster than im used to . Its like I floor it and boom, vtec comes in. I fuckin luv it.
I gotta say for the money, this mod is so amazing and everyone should seriously get a pulley.
-Mark
-Mark
#126
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
-Mark
-Mark
The headers must make a big difference!
mine is not really to noticable unless i really get on her then its noticablr a little...Dam i NEED headers...
mark, did u put your headers on yourself?
#127
-Mark
-Mark
#128
I Blaze Up In
And yea I put them on with a friend, it took about 4-5 hours. The hardest part was taking off the rear exhaust manifold and re-torquing the nuts on the rear headers.
All mods will have more of an effect when they work with other mods.
-Mark
#129
I Blaze Up In
So what are we talking about? Like under 1lb? Cuz the difference in weight between the stock pulley and the Option or UR pulley is like 7lbs, maybe more. And if it wieghs so little then I gotta question durability.
-Mark
-Mark
#131
yes im sayin the pulley is a great cheap mod ... but light weight tires and wheels have an even bigger affect ... u can cut out 50 lbs plus of roational mass some have suggested it can be the equivilant of 150 lb static weight loss
#132
I Blaze Up In
Speaking of wheels, does anyone know how much our stockies weigh? Im thinkin like 26lbs, maybe more?
-Mark
#133
'01 tire n wheel 55 ea.
#135
B A N N E D
Mark, Maybee when I get some headers you can get a lift and help me put it on. I gotta get it first still up in the air on wheater i will be get Megan or OBX headers... I wish XS still was making headers that would be a no brainer!
#136
I Blaze Up In
-Mark
#137
I Blaze Up In
Yea, like I had to take off my wheel/tire yesterday to do the pulley and it did not fel like 55lbs. Maybe 35lbs but definitley not 55lbs, but then again the weight is spread out so it isnt like your lifting a 55lbs stone that has all its weight densly packed into a small space. Were talking about 55lbs being spread out 22-24 inches across and 8inches wide so maybe thats why it feels lighter than it really is
-Mark
-Mark
#140
-Mark
-Mark
im gona weight them soon just to see how much they weigh
#141
lowrd on tein CS biatch
finally got that puppy put on!!! Belts worked out just fine, and it is a little faster for sure. shifting is smoother (no miracles but yes... smoother). the Acura dlr needed their BIG BOY impact to get that damn thing off. Wish I had one but it was much cheaper than buying on for a particular job.
#142
#143
-Mark
-Mark
#144
anyone know if 600ft lbs. torque is strong enough to undo the crankpulley bolt? or is 1000 required?
i tried doing this manually with all methods described in this thread (twice) and it still won't. will try impact guns next, then will bring to shop if all fails.
#149
i'm gonna try for the 600 this weekend. if it doesn't work, then getting the 1000. buddy insists 600 with the honda tool will take it off cause he's done it on hondas...
i blipped that thing like 5 times grr...
#150
skip the buddy .. pull the fuel pump fues or ignition or both . crank the car not just blip and itll come off
#151
just slapped on my option racing pulley. Took me about 2 hours (20 min break) and everything works fine. At first m idle was a little higher then normal but it dropped to normal idle. Having both stock and the option pulley in my hand, there is a big weight difference. The only mod on my car is a semi cold air intake. Hopefully i notice some power gain. If not im looking for xs headers if anyone has them stored..
Option Pulley
Option Pulley
#154
Option Pulley
Option Pulley
#156
i sprayed wd40 on it, waited 10 min to setup my breaker bar and a pipe to do the starter method. didnt take any fuse out either i just turned the engine for not even a split second. I heard a crack and the pipe falling and i didn't think i did it right. I went to loosen the bolt and it came right off with little effort.
#157
Oh wait only 19? that could get me in trouble.
#158
#159
Well, I had it installed today by a trusted mechanic.
I also had timing belt work done as well.
However, we both noticed now that the car is making some UNGODLY noise when turning left and less so (same noise tho) when turning right.
He thinks the pulley isn't "doing enough" (my words, sorry cant' remember what he said) to move the belt with low speed turns.
I popped the hood later on and see fluid directly underneath PS reservoir but it's not empty, etc... what in the world??
Any ideas?? i'm worried...
