jacking points
Old Apr 11, 2004 | 10:13 PM
asloudasitgets's Avatar
jacking points
i just put my 19's back on using a 3 ton craftsman floor jack, and well the cup that lifts the car on the jack was so big that when i jacked the car up using the points on the car it bent them. now the 2 jack points in the front of my car are bent.
can anyopne take a pic of where eles it is ok to jack the car up from?
also do you guys know how much this will cost to repair? the jacking points?
Old Apr 12, 2004 | 10:58 AM
does no one know?
Old Apr 12, 2004 | 11:14 AM
Shawn S's Avatar
With a small floor jack use the same lift points where the factory scissor jack goes.
They are on the sides directly behind the front wheel and just forward of the rear wheel.
Read the manual.
I think you used the front TIE DOWNS to lift your car which is a big NO-NO.
Those are just meant to hold the car down when being towed on a flatbed.
They bend real easy.
If you have a LARGE floor jack you can use the REAR center tie down as a lift or the cross member right under the engine.
Old Apr 12, 2004 | 11:16 AM
Shawn S's Avatar
AQUI NO!'s Avatar
It's not over yet
u can jack up the car upfront by using the tow hooks. u can also lift the car directly at the frame , i'll try to take a pic later tonite.
Old Apr 12, 2004 | 11:18 AM
Shawn S's Avatar
NO, they will bend.
Old Apr 12, 2004 | 04:09 PM
can you take a pic of what this looks like?>
i swear this is where the manu. says to lift the car from.
below the car where my side skirts are there is a small arrow that points to them. and thats what the manu. says to life the car from.
can you take a pic of where you are trying to explain to me, cause im confused.
thanks
Old Apr 12, 2004 | 07:30 PM
Shawn S's Avatar
thanks
Sorry, no new pics right now.
If it’s behind the front wheel and in front of the rear wheel then you lifted at the correct point.
I don’t know how you would have bent this.
I’ve lifted my car there with the above pictured jack many times and it’s fine.
I just put the “cup” of the jack entirely around the piece that projects from the car.
The tie downs I was speaking of are forward of the front tires.
Old Apr 12, 2004 | 09:13 PM
BC's Avatar
BC
nearsighted visionary
I put a chunk of 2x4 hardwood in the cup of the jack. Just have the woodgrain perpendicular to the steel jacking point plate. Steel on steel = slippage.
Old Apr 12, 2004 | 10:38 PM
JaDia4's Avatar
Censored User
From: Miami - just one day, I would like to drive without getting cut off!
I was trying to put on my rear sway bar yesterday and when I jacked the car up, the floor jack was so wide that I couldn't fit the jackstand under the lift points. So I jacked up the front at the lift points, which also lifted the rear enough to fit the jackstands underneath.
Old Apr 12, 2004 | 10:48 PM
JaDia4's Avatar
Censored User
Originally posted by Shawn S
Damn! Your jack goes high. BTW your ride is looking pretty hot!
Old Apr 13, 2004 | 01:15 AM
well there are 4 of these in between the front and rear wheels.
so i think i did not jack where you thought i did.
but from my perspective, the stock jack points are weak. its a thin piece of metal i mean come on how much weight can this support.
the thing is my cup on my jack is wider than the stock lifting point that one end hit the cup but the other end was inside the cup so it bent it. i mean why couldnt they make the lifting point a nice wide piece of steel so that you dont even have a chance of bending....
Old Apr 13, 2004 | 06:56 AM
Shawn S's Avatar
The “tabs” that stick down from the bottom of the car sit ENTIRELY inside the “cup” of my floor jack so it’s not even really touched when the car is lifted.
That’s why I can’t figure out how you could have bent it.
All it really does is keep the car from sliding out of place.
When I jack from the CENTER lifting points like shown in the photos above, I put the jack-stands in the factory lift points and then lower the car onto them.
I’ve done this many times on my 2001 & 2003 CL’s and never had a problem.
Shawn S
Old Apr 23, 2004 | 06:38 PM
any luck on those pics yet?
Old Apr 23, 2004 | 06:57 PM
blader's Avatar
Audi S4 driver
I bent that tab also, actually I think two of mine are bent. my floorjack touches them. I've heard of other people bending them too.
Old Apr 23, 2004 | 09:35 PM
so what you do to jack the car now?
is it ok to jack it up using those tabs still? as long as they are in the cup of the jack?
Old Apr 28, 2004 | 02:31 PM
AgentDSS's Avatar
Black is a ***** to Clean
I bent those tabs too. I just use the area around it (not the side skirt of course) that seems solid.
Old Apr 28, 2004 | 05:14 PM
blader's Avatar
Audi S4 driver
I use the frame, behind the tabs.
Old Apr 28, 2004 | 05:26 PM
car_lost's Avatar
what can we do to bend them back to normal? one of mine is bent as well
Old Apr 28, 2004 | 05:34 PM
blader's Avatar
Audi S4 driver
I wouldn't, ever bend a credit card? keeps getting weaker and weaker. if you keep bending it back it might snap one day and that wont be good
Old Apr 28, 2004 | 11:04 PM
Pure Adrenaline's Avatar
Dragging knees in
Have a shop take it off completely and weld a new one back on. They shouldn't charge more than like 20 bucks to weld one on.
Old Apr 29, 2004 | 05:06 AM
LiQiCE's Avatar
Liquid Ice
Yeah my front passenger side jack point got bent ... I just use the area behind it (which should be part of the frame). No big deal ... I'll probably start using the front jack point (like in Shawn's pics) and then just drop my jack stands on/around the jack point area.
Old Apr 29, 2004 | 09:18 AM
car_lost's Avatar
i just wanna bend it back to normal. i havent used the jack points any more... i get a piece of wood and put it right next to the jack point and jack it up on that.
Old May 19, 2004 | 12:57 AM
where do you put the jack stands?
Old May 19, 2004 | 07:36 AM
Bluto's Avatar
Find beauty in dissonance
The tabs fit into the slot on the jack in the trunk. They are intended to ensure proper placement (and no movement) of the factory jack when changing a flat tire. The won't hold the weight of the vehicle.
The cup on my floor jack and jack stands is not big enough to reach around the tabs to the frame.
Shawn, you must have a big cup size. :o
I use 2 X 4 wood on the frame + jack stands, in the stock jack locations. I use the jacking points Shawn posted.
Old May 19, 2004 | 07:50 AM
Shawn S's Avatar
Yea, it’s about 4-5 inches across and the factory tabs easily fit completely inside.
Mike734
Dec 10, 2021 01:25 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
