is the J32 an interference engine?
Old Jul 23, 2007 | 12:28 PM
SkillOBskilled's Avatar
Is the J32 an interference engine? Meaning do the valves and the pistons take up the same space during opposing strokes.
I got that UR pulley, and since I fairly certain that this is an interference engine, I m going to have a mechanic do that work.
Old Jul 23, 2007 | 12:52 PM
mrdeeno's Avatar
Yes, i am positive it is an interference engine.
Old Jul 23, 2007 | 01:11 PM
2CLean's Avatar
Well...it's kinda fast...
Old Jul 23, 2007 | 02:53 PM
TheWeez's Avatar
I Wanna Beer
Sure is. The shop I've always gone to recommended I make sure I do the timing belt right on time. They had just had to replace all the valves on another CL-S who's timing belt had snapped. $4200 in damage.
Old Jul 23, 2007 | 04:57 PM
JBlueCLS6's Avatar
He could have bought 2 engines for that price.
Old Jul 23, 2007 | 05:17 PM
mrsteve's Avatar
S They had just had to replace all the valves on another CL-S who's timing belt had snapped. $4200 in damage.
The fully assembled heads only cost about $1,000 each brand new from Honda so $4,200 for a complete replacement is a hell of a lot in labor charges. If $4,200 was truly the price they ripped someone off.
Zippee's Avatar
Why would the fact that it's an interference engine make a dfference in who does the pulley swap?
Old Jul 23, 2007 | 05:19 PM
mrsteve's Avatar
I'm also confused on that one.
Old Jul 23, 2007 | 06:11 PM
Zippee's Avatar
Could be there was some piston damage in there, too. That would drive the price up a lot.
Old Jul 23, 2007 | 07:09 PM
nbennettksu's Avatar
i heart latin chicks
isnt that how they got the name stealerships?
Old Jul 23, 2007 | 07:14 PM
jproy's Avatar
MP90 uninstalled
The pulley doesn’t affect the timing of the valves. Also it will only go on one way because of the notch in the crank pulley and the inversly matching notch on the crank.
Old Jul 24, 2007 | 04:20 AM
mrsteve's Avatar
A new piston costs less than $100.
Old Jul 24, 2007 | 07:23 AM
Why would the fact that it's an interference engine make a difference in who does the pulley swap?
Well the timing belts runs of the crank, so if you dont do the swap correctly, you could potentially mess up the timing. There is a way to align everything to be sure your putting the new belts on with all the pulleys in correct positions, but I m just not that confident that I wanna take on that liability.
Old Jul 24, 2007 | 07:54 AM
Starter's Avatar
Yeah, but you have to open the bottom end to get to it. Labor.
Old Jul 24, 2007 | 07:57 AM
fuzzy02CLS's Avatar
Your confused I think. The belts for the pulley are the rubber drive belts that run your accessories.
The timing belt is in the engine. The pulley just unbolts & bolts back on. There's a notch on it so it will only go on 1 way.
Old Jul 24, 2007 | 09:18 AM
That I did not realize, well that answers my question.
Old Jul 24, 2007 | 10:23 AM
typeR's Avatar
point is i dont think a brand new entire long block plus labor is 4200$
Old Jul 24, 2007 | 10:46 AM
fuzzy02CLS's Avatar
Complete long block with labor for my Explorer is $3500. It's a lot less complex as well.
Old Jul 24, 2007 | 11:09 AM
Zippee's Avatar
From H&A's web site: list price for a short block is $1897, the heads are $2741 for a pair.
Old Jul 24, 2007 | 01:46 PM
fsttyms1's Avatar
The crank runs the timing belt. You are replacing the crank pulley which runs the alt and ps belt, not the timing belt. You wont be messing with the timing replacing the pulley
Old Jul 25, 2007 | 11:25 AM
mrsteve's Avatar
That doesn't mean you can't find one for much cheaper. Also, with bent valves there would be no reason to replace the entire block. Arguing this point is pretty irrelevant.
Old Jul 25, 2007 | 11:39 AM
TheWeez's Avatar
I Wanna Beer
I don't know the total extent of the damage. All I know is they told me it was $4200. Could have been more then bent valves (likely was) and they could have had other work done at the time. I'm sure labor was included in that price too.
Old Jul 25, 2007 | 11:46 AM
CleanCL's Avatar
and even cheaper in some places
Old Jul 25, 2007 | 12:07 PM
Zippee's Avatar
Depending on how fast the engine was turning when the valves hit the pistons, it is very possible that the pistons or the cylinder bores are damaged. I have seen some where the valve head seperated from the stem and pretty well garfed up everything.
Even with the discounted prices you quote, short block and heads is over 3700-add in 500 labor to do the change out and bingo, you have a 4200 bill.
My point is that 4200 may not be unreasonable depending on the damage.
Old Jul 25, 2007 | 12:13 PM
TheWeez's Avatar
I Wanna Beer
Exactly. It's not a horrid price. Most shops aren't going to shop around online and find the place with the lowest price on parts. They're going to go through their normal parts supplier and in many cases something like this would be gotten through Acura directly. Point of all of it is that it pays to have the piece of mind that a your maintenance is up to date. Even if it cost $1000 to repair, that's still a hell of a lot more then what it would cost to replace your timing belt.
Old Jul 25, 2007 | 12:52 PM
mrsteve's Avatar
My point is that for a rebuilt or replaced valvetrain/head it shouldn't cost $4,200. Someone suggested the hypothetical that maybe the block was damaged too.
In any event there's no reason to go back and forth any more.
SidhuSaaB
May 30, 2020 12:40 AM
BIGxRED
Oct 19, 2015 10:47 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
