its happening already????
9.5 lbs o' Boost!!!!
iVE ONLY HAD MY CAR BACK FOR ABOUT A WEEK AND im noticing some strange boost levels. Whats happening is that at WOT, the boost is about 6 lbs, then when it reaches about 6k RPM the boost goes to 0 and the fuel pressure goes to 80 LBS. The car just looses power because its not getting boost or fuel. No idea what it can be? Belt maybe? I know someones gotta know about what it is, so someone help!!! PLEASE.
1 Post
Sounds like belt slip....but if that was the case then you would see boost come back around 1-2psi...build up again and start slipping at higher boost levels. Unless the belt is glazed from slipping a lot.
yeah thats what i though but im wanted to make sure and see. I was hoping it was not anything serious. how is the belt gone already? do i have to get a heavier duty belt?
Originally Posted by derelict
Just needs to be re-tensioned since the belt stretches a little after you've used it for a few hundred miles.
gotchya. Thank you.
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
SidhuSaaB
05-30-2020 12:40 AM
