Issue With ballast WIRES
To many cars in my garage
So my headlight went out,
So I switched the bulbs too find out it was the ballast
So I replaced the ballast
But The thing is it woulnt work so I tested the wires and this is my issue it seems like there is not enought voltage getting to it cause my test light is not bright at all
any suggestions?
any suggestions?
Regional Coordinator (Texas)
i think our ballast have an ignitor built in. right?
it cant be a relay if its getting even a little bit of power.
try hot wiring the ballast and see if it work thens.
^^ Ha ha, there all off right now I got sick of them, for now
Yeah, it works when I hook it straight to the battery, and the ignitor is built into the ballast.
I dont really know much about relays but thats why im asking cause I cant think of anything else
I Drive Like A Dick 8≈
When you check to see if there is power going to the wires do you stab them??
My buddy was fixing his sisters car once who was having a similar issue and it turns out that water had gotten into one of those little holes that had been poked in and rusted the wire.
There wired on a seperate circiut but that was a good suggestion and makes me think of something that maybe causing a problem..... the plugs for the old fogs could be shorting im going to check that out tmmorow thanks
Concave All Da Way!
defective!? damn i hope not lol. i order the rite set 3k, maybe some fool gave me a diff temp color cus one is orange and the other is yellow. ill try to take some pix 2nite.
so u figure out whats wrong with ur headlights?
No but right now I got it wired right to the fuse box so it must be the wires
I was busy today, went in for a final interview and got a new job!!! Ill be selling lambos lotus's and vipers saturday!!! sweet
Whats up with RDX owners?
(Mid-Atlantic)
(Mid-Atlantic)
congrats on the new job, definitely sounds like a loose wire somewhere or bad ground
Yeah I think for now im going to keep it hooked right into the fuse box because its been working for now and its going to be bitch tracing the wires to find the issue
Fair enough.
i have the exact same issue as you Mr.Fluffy.
everything's in pieces as i drive the family van around...
i think i may give in and bring it to a shop to check it out.
bought ballast/bulbs. checked fuses. giveup.
I got mine working I just ran a wire from the fuse box for power and grounded it on the body worked for me but its no pretty I would do this If I were you if you need more info on it just ask
cycdaniel
12-17-2019 10:58 AM
BoricuaTL
04-08-2016 01:08 PM
gehrlichman
09-22-2015 10:08 AM
