Intermittent Stalls When Cranking
Old Mar 26, 2015 | 06:41 PM
dcbakerphoto's Avatar
I have a 2001 3.2 CL S. Sometimes when turning over the ignition, the car will turn over like it's going to crank and then immediately stall out. Two or three times and it cranks up fine and runs normally. Sometimes it seems to idle really low at a stop. It runs good except for the intermittent times where it doesn't want to stay cranked. I replaced Fuel Pump Relay so I don't think that's it. No check engine code/warnings are coming up. Could this be electrical? Ignition? Fuel pump? Any suggestions on what the issue could be would be greatly appreciated. Thank you in advance.
Old Mar 26, 2015 | 09:12 PM
teh CL's Avatar
Check your grounds
Old Mar 27, 2015 | 08:06 AM
Scottyknows007's Avatar
Ive actually had this same thing happen to me a couple times now.
Teh-
When you say check your grounds are there certain grounds to check first? Im sure there are tons of grounds on our car!
Old Mar 27, 2015 | 10:52 AM
teh CL's Avatar
Just the grounds in the engine bay, can't remember how many there are right now..
Unbolt em, sand down the contact points & re bolt em down
Old Mar 27, 2015 | 04:42 PM
Dude. Pulled the battery out. Grabbed ground wire and moved it back and forth and it cam right off. Put a new ring terminal on it, hooked everything back up and it fired right up. Seems to have fixed it. Good call! I appreciate it!!!
Old Mar 27, 2015 | 10:20 PM
teh CL's Avatar
No problem
Grounds are usually overlooked when ppl are diagnosing a problem.
acuratl26
Apr 23, 2020 07:30 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
prbori
Sep 27, 2015 01:37 AM
Brandle34
Sep 23, 2015 07:20 PM
rklatzkin
Sep 23, 2015 04:08 PM
