Interior LED Upgrade Info
Just found this site on Ebay and looks pretty useful if you plan on upgrading the lighting in the TL/CL's interior LEDS. Hope this helps someone....https://acurazine.com/forums/newthre...newthread&f=1#
Wish
http://www.ledautomotive.com/HowToGu...imateHowTo.asp
Wish
woooo!!
Originally Posted by cltphantom
here's a thread of the same thing on that other board. it gives detailed instructions and the type resistor to use. it's on a accord, but they share the same when it comes to voltages. this link is a repost. have fun
http://v6performance.net/forums/show...=&threadid=548
![Thumbs down](https://acurazine.com/forums/images/icons/icon13.gif)
I decided to give this a shot tonight-- The instructions for pulling out the instrument cluster are pretty good, but when it comes to the actual replacing the bulbs with LED's they must have just put in some generic info-- The bulbs in my '03 CLS-6 aren't anything like the ones they give instructions on how to replace... (well, maybe they are for the clock, but not for the instrument cluster)
In any event, I used a regular sized (not surface mount as they suggest) 500 ohm resistor and soldered it onto the lead of the LED and then bent the remaining leads into a "spring" and wedged it in the plastic sockets... there are 5-6 bulbs that need to be replaced for the gauges (not including all the indicator lights).I then sanded down all of the rounded tops to diffuse the light--
After some trial and error with the polarities, they all work-- on the good side, the instrument cluster numbers no longer are yellowish green-- they're a cool whitish blue-- all and all its pretty even (no hotspots), but apparently I didn't get bright enough LEDs...
In any event, I really like the new look, but with my current LEDs its nowhere near bright enough-- Off to ebay, I just purchased some 20,000mcd white InGaN LEDs (the ones I have in there right now are 5000mcd)... I'll post some pictures when the new ones get here.
_Larry.
_Larry.
_Larry.
_Larry.
handsom-hustla
11-13-2015 05:04 PM
09-17-2015 09:01 PM
