Intercooler shipment received
Old Dec 23, 2004 | 05:31 PM
Smitty's Avatar
the 2 boxes.. (1 MrSteve) (1 Smitty )
Scalbert, nice packing job....(those damn peanuts where everywhere!)..
Steve, what is this for?..spacer and washer for pulley???
Lots O bubble wrap
More Bubbles
Holy hell... there it is... was wondering if I was going to bubble wrap the entire Funeral Home floor...
The Welds are awesome...
more boost.... bet they will have no clue when they see this sleeper in their review mirror...
Thanks Scalbert , you made my Christmas one to remember!!!!... I will polish the intercooler next week and install one weekend in January.... I will be in touch...
Old Dec 23, 2004 | 05:34 PM
NSX-Tuner's Avatar
boosted is best
Hey, it's Christman, no red ribbons?
Chemmech's Avatar
The boxes are HUGE aren't they ?
Old Dec 23, 2004 | 05:40 PM
Smitty's Avatar
yeah, the UPS guy hates me with a passion.... he was laying on the horn when he pulled up...
Old Dec 23, 2004 | 06:27 PM
NiteQwill's Avatar
Adventurist.
Yea, Steve goes absolutely NUTZ with the bubble wrap and PEANUTS! When I received my things from him I was seriously lost in all the stuff. The bubble wrap is fun afterwards though.
Old Dec 23, 2004 | 06:57 PM
Allout's Avatar
Blown is Best
Those boxes are so big that he was probably worried that someone was shipping you a body
That should look very nice polished up under the hood. Congrats
Old Dec 23, 2004 | 09:19 PM
darrinb's Avatar
///M POWER
congrats, thats teh shit smitty
u got the hbp too right??
Old Dec 23, 2004 | 09:22 PM
Smitty's Avatar
Yep..4th pic.. lower right right below the res. tank...
Old Dec 23, 2004 | 09:24 PM
darrinb's Avatar
///M POWER
sweet!!
Old Dec 23, 2004 | 09:36 PM
ChadT's Avatar
Spectacular Aroma About
Wow that's some serious hardware! Is there another radiator for the IC or just that big tank? Looks like a nice rig. A couple of days ago it was like 5 degrees and dry out here. I was thinking it would be nice to get the S/C and experience that kind of power all the time.
Old Dec 23, 2004 | 11:13 PM
scalbert's Avatar
That is the FPR re-cal kit. That will decrease the ramp rate of the fuel pressure. It will still go over 90 but not near as often. In other words, much better for the fuel system.
Hey, I tried to make it complete and I am glad you like it.
Old Dec 23, 2004 | 11:18 PM
scalbert's Avatar
Technically he had the HBP which is the 3.275 inch alternator pulley. He now also has a 3.5 inch SC pulley (down from the base kit's 3.8 inch). From what I can tell, an even smaller pulley could be run with the IC to get upwards of 9 PSI boost; maybe a little more.
In other words, I see no reason why a CL-S6 SC/IC couldn't easily make 400+ WHP. Now using it is a different story.
Old Dec 23, 2004 | 11:19 PM
scalbert's Avatar
Not enough margin to cover red ribbons.
Old Dec 23, 2004 | 11:20 PM
scalbert's Avatar
Hey, I worked for UPS many years ago and know how packages are handled.
Old Dec 23, 2004 | 11:21 PM
mrsteve's Avatar
Looks good. Maybe I don't want to wait till late February to install it.
Steve, do I need the FPR re-cal to use with the E-Manage prior to the IC is installed?
Old Dec 23, 2004 | 11:23 PM
scalbert's Avatar
Yes, two copper heat exchangers (GM van heater cores actually) will be shipped on Monday for each system. It turns out my torch welding isn't as good as my father-in-laws and needed some touching up.
mrsteve's Avatar
One more thing. Did you ever think of using braided stainless steel lines for the coolant to dress it up a little?
Old Dec 23, 2004 | 11:24 PM
scalbert's Avatar
No, but it does relieve some of the over pressuring.
Old Dec 23, 2004 | 11:25 PM
scalbert's Avatar
Did you want to pay $500+ more for it?
Yes, but it was cost prohibitive. Heck, there is about $75 worth of hose in it already.
Old Dec 23, 2004 | 11:27 PM
mrsteve's Avatar
I might need to check my FPR and/or fuel pump soon. In 1st, 2nd, and 3rd gear i'm maxing out at 86psi and dropping back off to around 78psi at redline. In 4th and 5th gear at WOT I still see 95+ psi. No pinging is heard, and I was running pig rich on my dyno, but back then I was seeing 95+ psi at WOT in all gears and backing off to 85psi by redline. I gotta get that wideband hooked up next week.
Old Dec 23, 2004 | 11:30 PM
scalbert's Avatar
I see a problem!! That is not the correct pump.
Although it will work fine it is the smaller of the two I have used. I used that one on my old Typhoon as did many other individuals. But the one I used with this kit so far was the 750. It has a higher flow rate.
Can you check and see if both are 500's?? Let me know and I will run to Wal-Mart and pick up the correct ones. I had grabbed them quick early one morning (about 5:30 AM) and didn't really look.
Old Dec 23, 2004 | 11:40 PM
mrsteve's Avatar
Those welds look great. Hmmmm maybe I want mine polished too?
Old Dec 23, 2004 | 11:52 PM
mrsteve's Avatar
Smitty hit me up on IM err something tomorrow, I have a good idea on how to mount the wideband O2 gauges we purchased.
Old Dec 23, 2004 | 11:53 PM
scalbert's Avatar
Which one did ya'll go with??
Old Dec 23, 2004 | 11:56 PM
mrsteve's Avatar
AEM. $405 shipped. Included the O2 sensor, gauge, etc.
The center section of the gauge shows the true AFR. And there are 24 multi-color LEDS that go around the outer edge.
Old Dec 23, 2004 | 11:58 PM
mrsteve's Avatar
Steve,
I just sent the payment for the remainder of my balance.
scalbert's Avatar
That is a nice unit!!
Old Dec 24, 2004 | 12:00 AM
mrsteve's Avatar
The only problem we may have with it is that the wiring harness to connect the gauge wiring to the sensor is about 1" x 1". It might be difficult to fit that through the firewall without cutting the wire and then re-connecting it after the wires have been routed.
Old Dec 24, 2004 | 12:01 AM
scalbert's Avatar
I had to cut and solder mine. Just FYI...
Old Dec 24, 2004 | 12:05 AM
mrsteve's Avatar
That's the plan, unfortunately. I'm trying to find time next week to have the bung welded. After that I'll hook it up.
Old Dec 24, 2004 | 02:02 AM
bullaculla's Avatar
I hate you guys.
That is beautiful tho. Haven't been around much lately. I didn't even know you finished the IC project. good job!
Old Dec 24, 2004 | 11:03 AM
Excelerate's Avatar
Former Sponsor
I am so damn jealous of you guys and your 6 spds and S/C and I/C kits. That could have been me.. j/k.. I'm happy for you guys. Everything looks great and props for putting quality parts on a quality car.
Josh
Excelerate LLC
Old Dec 24, 2004 | 11:28 AM
Seattle Cl-S's Avatar
Blown LS6!!
Josh
Excelerate LLC
I'm green with envy as well... I thought MrSteve had an auto?? If I knew someone up here in Seattle that could install this stuff I'd seriously consider the IC. As soon as we start seeing MrSteve's 12 second runs I know I'm gonna catch the fever.
Old Dec 24, 2004 | 11:56 AM
mrsteve's Avatar
I do have the automatic transmission.
Look for a 12.x time slip on March 5th. That's when the tracks open. Unless someone decides to rent out a track prior to then.
Old Dec 24, 2004 | 12:38 PM
ThinJim's Avatar
Couple of questions for scalbert...
What kind of tank is that (Make) you provide in your kit and what is the capacity?
In regards to the pump, where does it attach? on the tank or between the tank and IC?
Several weeks ago you mentioned you were, with your father in law, looking for an early model Chevrolet. Have you found one. Sorry for the off topic question, just wondering.
That kit looks great guys, if I were'nt going off in a different direction, I'd have a blast with those performance mods.
One more thing, why use the AF meter instead of EGT guage. I've been under the impression that EGT can tell you more that the AF meter. Just wondering.
Also, since the emanage system is piggybacked off the ecu for timing and other control, has anyone looked into a system that detects knock on individual cylnders and has the capibility of retarding individual cylnders rather than retarding all six of them when the knock detecter detects a knock? Knock Knock?
Great mods to you guys, more on mine in future weeks.
Old Dec 24, 2004 | 12:53 PM
mrsteve's Avatar
There was a thread a few months ago regarding EGT vs. AF.
Basically we said EGT would work, but no one knew what the proper temp should be for normal operation, where to mount to pyrometer for proper readings, etc. Also, the EGT values will change as ambient temperature changes.
There is no reason an EGT wouldn't work, it would just take a little more playing around with to make it work for you becuase it would require a little experimentation.
Old Dec 24, 2004 | 02:53 PM
Chaptorial's Avatar
Xmas came one day early.
Can't wait to see the slip(s).
Old Dec 24, 2004 | 03:14 PM
scalbert's Avatar
That is just a Summit Racing 4 gallon vertical fuel cell.
It is place in line near the tank.
Nothing yet, we are waiting until after the new year to begin serious planning.
The EGT tells only part of the story about the Air/Fuel ratio. Although it is important the A/F ratio, if it can be measured, is certainly a better tuning value to use.
Nope, I haven't seen a piggy back system which has that capability.
Old Dec 24, 2004 | 03:55 PM
ThinJim's Avatar
Thanks scalbert.
Old Dec 24, 2004 | 04:28 PM
Chopsie's Avatar
Beware of leakage
Looks awesome guys, more power
