Intercooled SC Dyno
Old Jun 29, 2004 | 03:34 PM
  #121
mrimage27's Avatar
so the total power is 320?
Old Jun 29, 2004 | 07:09 PM
  #122
scalbert's Avatar
My dyno with a good A/F ratio and no knock came in at 315 WHP. It is the red line in the original plot in this thread. Keep in mind, this was also through the stock cat back exhaust.
Old Jun 30, 2004 | 02:59 AM
  #123
dukmahsik's Avatar
how does the tranny hold up???
Old Jun 30, 2004 | 07:13 AM
  #124
scalbert's Avatar
For me, just fine as I do have the 6-Speed manual.
Old Jun 30, 2004 | 11:36 AM
  #125
mrimage27's Avatar
what kina a clutch you use steve?
Old Jun 30, 2004 | 11:38 AM
  #126
mrimage27's Avatar
what kind a clutch you use steve?
Old Jun 30, 2004 | 12:03 PM
  #127
scalbert's Avatar
Stock clutch for now and the forseeable future.
Old Jun 30, 2004 | 12:12 PM
  #128
mrimage27's Avatar
steve your clutch can't handle all that power, clutch master makes a stage 3 for $1500
Old Jun 30, 2004 | 12:14 PM
  #129
scalbert's Avatar
The clutch is holding up fine. The tires are currently taking the abuse. I suspect that if I run slicks at the track the clutch will begin to seriously degrade, among other things.
Old Jun 30, 2004 | 12:46 PM
  #130
Smitty's Avatar
<--- still waiting for in anticipation......
P.S. Eric decided to keep his car if you did not hear... so I am sure he is waiting for an Intercooler for 6-speed too...... just PM us when your ready.
Old Jun 30, 2004 | 01:07 PM
  #131
brian6speed's Avatar
Lone Wolf
can that fit the 03 cl. i thought the comptech was the only clutch available.
Old Jul 1, 2004 | 12:57 AM
  #132
sgmotoring's Avatar
Bleed Honda Blue
SCALBERT can you post your site again? Thanks
Old Jul 1, 2004 | 01:49 AM
  #133
sgmotoring's Avatar
Bleed Honda Blue
Finally found the search button.
Old Jul 1, 2004 | 01:53 AM
  #134
Smitty's Avatar
HOPE SYSTEMS
http://www.hopesystemsinc.com/index.asp
Scalbert is the CL-S's last hope
Spectacular Steve puts down 369 WHP
Steve knows his shit
Smitty is waitng for a PM and wishes to purchase all in stock items
Pic one... take you to the same place and you will get the best service around...
Old Jul 1, 2004 | 06:57 AM
  #135
scalbert's Avatar
Old Jul 1, 2004 | 11:14 AM
  #136
ModAddict's Avatar
Old Jul 1, 2004 | 02:15 PM
  #137
MisterMehoff's Avatar
If He Dies...He Dies
Scalbert, did Comptech reply back to you about your dyno?
Old Jul 1, 2004 | 02:17 PM
  #138
scalbert's Avatar
Nope, nor did I expect them to.
Old Jul 1, 2004 | 02:25 PM
  #139
Chemmech's Avatar
Since the factory intake manifold is replaced, what is the power delivery like? From the dyno it seems to be very linear.
Old Jul 1, 2004 | 02:29 PM
  #140
scalbert's Avatar
Bingo, it is very linear. There is not sudden change in power anywhere. It starts pulling down low and slightly starts gaining in power. And at no point does it feel like power drops off.
Old Jul 1, 2004 | 02:44 PM
  #141
Chemmech's Avatar
Old Jul 1, 2004 | 02:46 PM
  #142
so when could we expect full scale production on the S/C? ...also the Intercooler?
Old Jul 1, 2004 | 02:48 PM
  #143
scalbert's Avatar
I won't be producing an SC kit. But the production of the IC has begun. Well sort of. I don't expect to be selling many of the IC kits so they are a build to order item. But one is under going production.
Old Jul 1, 2004 | 02:50 PM
  #144
Chemmech's Avatar
Takes about 8 weeks for delivery, or maybe alittle sooner ?
Old Jul 11, 2004 | 08:23 PM
  #145
what's the cost of the whole IC kit?
Old Jul 12, 2004 | 07:10 AM
  #146
scalbert's Avatar
Here are the details and options:
http://www.hopesystemsinc.com/intercooler/IC_Main.asp
Old Jul 12, 2004 | 07:28 AM
  #147
excuse me if I ask dumb questions, but would I need the SC in order to install the IC? In the pics on your site, you have an SC'd CL-s coupled with the IC on top.
Old Jul 12, 2004 | 07:30 AM
  #148
mrsteve's Avatar
Yes the intercooler is only for a S/C application. It cools the charged air to allow for higher boost. Cooler air, more dense, more HP. I don't know how long our engine would last at 8psi of non-intercooled boost.
Old Jul 12, 2004 | 07:49 AM
  #149
scalbert's Avatar
Yes, the SC is required.
Old Jul 12, 2004 | 07:50 AM
  #150
scalbert's Avatar
I may last a while but you wouldn't be making the power you could. The knock would probably be killing the power making it pointless to run that high.
Old Jul 15, 2004 | 07:58 AM
  #151
mrimage27's Avatar
scalbert you think it is possible to build a front mount intercooler for the sc?
Old Jul 15, 2004 | 08:44 AM
  #152
scalbert's Avatar
Nope, the FMIC would be air/air and is not a good idea on a roots blower. Unlike a turbo where if can flow extra air until the desired boost is reached. A roots style blower flows a fixed amount.
All the additional piping in a FMIC system with a roots style blower would decrease response significantly. To the effect of about a second when you hit the gas. Versus right now the boost hits instantaneously.
But if it is the look you want then one of my current projects may fit the bill. I am creating a new heat exchanger system for the liquid/air IC system which will resemble a FMIC somewhat. That wasn't the purpose, I am trying to get greater efficiency out of the system, but it will be a result.
Old Jul 15, 2004 | 09:16 AM
  #153
mrsteve's Avatar
^ My Acura service advisor has an '04 s2k with the CT blower and aftercooler plus and additional heat exchanger mounted in front of the radiator. He said it really made a difference. Looks and is fast as hell.
Old Jul 15, 2004 | 09:27 AM
  #154
Chemmech's Avatar
What type of fluid should we be running in the IC Scalbert? Water + water wetter?
Old Jul 15, 2004 | 09:46 AM
  #155
scalbert's Avatar
I'm running straight water right now. But for winter I will switch to the 30/70 coolant/water mixture hust in case my car sits out over night and it gets cold. This is rare but I have to prepare for the worst.
Old Jul 16, 2004 | 09:50 AM
  #156
Are you talkiing about Lenny @ Tischer?
Old Jul 16, 2004 | 10:00 AM
  #157
derelict's Avatar
Brandon. Lenny has the sick white teg they park out front a lot.
Old Jul 16, 2004 | 10:07 AM
  #158
oh ok. Lenny said he was trying to create a website called www.tischerperformance.com for aftermarket parts all the acuras. I don't know if it's up yet.
Old Jul 16, 2004 | 10:23 AM
  #159
derelict's Avatar
Ya... he's been working on that for a while. Good stuff.
Now back to the topic!
Chemmech you're not worried about I/C'ing a blown 5AT?
Old Jul 16, 2004 | 10:46 AM
  #160
Chemmech's Avatar
Yep, alittle. Transmission has been troublefree so far.
