Intakes
Old Dec 8, 2001 | 04:21 PM
BLUETYPES's Avatar
Intakes
who makes the best intake for the cl-s AEM/INJEN/COMPTECH/ and do notice any differnence after installing a the AEM pulleys
Old Dec 8, 2001 | 04:30 PM
TypeSAddict's Avatar
is Pretty Much a Moron
The puleys don't make that big of a differance. The average driver wont notice. I prefer the AEM, but the AEm and Injen are very similiar. I don't belive that compthec makes an Intake.
Old Dec 8, 2001 | 04:31 PM
KingsFanPaul1's Avatar
2002 NBA Champs!!!
if you put an aem intake in will it make your car sound like a little bee? hehe. no offense to people that have cars that make that noise i just dont care for it.
Old Dec 8, 2001 | 04:57 PM
scl23's Avatar
Goldmember
Fan of InJen CAI
I got the InJen since it was 20 bucks cheaper and the shop guy said that there's no difference. The filter on the InJen is better than the AEM I think, although they may both be K&N. It's been great so far. It doesn't make hardly any noise until 5000 rpm and then the sound is not too loud and very nice. The sound above 5000 used to be a whirling hum, now it's more of a low tone growl and it sounds meaner and sweeter. Get the CAI, make sure it's the 3" set-up, get the air bypass filter. For the InJen, you can cut the pipe up top or just above the side holder bolt part.
Old Dec 8, 2001 | 04:59 PM
2002 NBA Champs!!!
is it like a mean or somewhat aggressive tone or is it like when i hear a ricer go by?
Old Dec 8, 2001 | 05:01 PM
BLUETYPES's Avatar
what is the heat shield for.
Old Dec 8, 2001 | 05:40 PM
DaBoomVatz's Avatar
CL Type Nice!
I have an Injen I installed myself, somewhere on this board this is step by step directions. Do a search for intake.
Anywho, your car will sound bad ass once it's installed. The idle is quiet exceptwhen the car is cold you will hear a suction noise.
Once it's warmed up and you hit V-Tech
oooohhh man sweetness.
Old Dec 8, 2001 | 08:55 PM
my2sense's Avatar
f-a-b-o-l-o-u-s
When the car is cold, my intake makes a whistling/whooshing-type sound when changing gears. I love it because I can pretend that I have a blow-off valve or something...
Old Dec 8, 2001 | 09:17 PM
Red Rider's Avatar
Subie Dubie
It's agressive, if it was ricey, it wouldn't be on my car.
Old Dec 8, 2001 | 10:01 PM
DeLucCL-S's Avatar
Mr. Lover-Lover
i have the AEM CAI. i love it..the sound is unnoticeable unit 4-5k RPM, then you get the growl. It doesnt sound rice to me.
The only time other than that that you can hear the CAI is on a cold morning and you just start you car up.....it i kinda like it is sucking up as much air as possible for a couple of minutes, but once you get moving, you ca barely notice it. Once the car is warm...the sound goes away and comes back only when you want it too....which is quite often once you hear and feel the CAI once!!!
Go with the RED AEM..looks nice as hell
Old Dec 8, 2001 | 10:08 PM
EricL's Avatar
Re: Fan of InJen CAI
Did you notice any power-loss (if you installed the bypass filter after your initial AEM install)?
I now have the AEM Bypass valve (in hand) and the inside of the valve is NOT the same diameter as the pipe (V shape on the inside too!). I checked the bypass valve by gently sucking in on it with the opposite end blocked; it opens, to the outside air, with the slightest suction (It also leaks out a bit too!). This “suggests” that “some” amount of hot air will mix with the colder air from the K&N (mounted down low).
I sure would be interested in a before-and-after impression of its install.
Old Dec 8, 2001 | 11:26 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
I have the injen intake. I did the install myself. I necer saw a dyno of this CAI on CL-S? Any Dyno?
Old Dec 9, 2001 | 12:44 AM
SilverKnight's Avatar
Retired. Not available.
With intake, your gas economy goes down .
People said it should be better but how could you resist the "sweet roar"?
Old Dec 9, 2001 | 03:11 AM
2002 NBA Champs!!!
probably been mentioned before and i could do a search for it but since we are already talking about it which aem cai would i get for my 97 3.0. i seen some for the honda 4cyl(2.2cl) and some for the 98-up v6 accord and cl but i dont know what to get for a 97 3.0 v6
Old Dec 9, 2001 | 11:44 AM
scl23's Avatar
Goldmember
Wouldn't CAI HELP fuel economy?
Since the air is colder, the fuel burns more cleaner and efficiently and thus better gas mileage??? I thought the only reason you get less is because you probably floor the gas pedal more now...
Old Dec 9, 2001 | 12:57 PM
1SICKLEX's Avatar
bluetypes.
The heat shield is to block away that hot, power robbing heat the engine emits. Technically the intake should be directed to a hole in the front end, so the cold air hits the filter directly.
Also an ECU for the intake, to adjust the amount of gas the engine needs as the intake opens up.......
Old Dec 9, 2001 | 01:48 PM
defrag's Avatar
yeah, that v-tech sounds awsome...
Old Dec 9, 2001 | 04:06 PM
my2sense's Avatar
f-a-b-o-l-o-u-s
blah.. that v-tech is only 900mhz. If you don't have 2.4ghz DSS, then you aint got nuthin!
my ear dyno feels more power off the line with the 2.4. Those 900mhz are lacking in the high-end power.
Old Dec 10, 2001 | 12:47 AM
EricL's Avatar
Re: Wouldn't CAI HELP fuel economy?
Any economy gains would probably be the result of decreased pumping losses -- less restriction. (Think of the power drawn from a vacuum cleaner when you stick your hand over the vacuum pipe; it has to suck harder, using more power to do so.)
You are correct about any "probable" MPG gains being negated with the application of a lead foot!
BTW -- the cold air would be denser and the car's computer would compensate by increasing the fuel delivered. It is possible that the emissions could change with temp -- but it would need testing on OUR car!
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
jmaxima03
Sep 27, 2015 10:22 AM
