intake spacer mod
intake spacer mod
i will make a diy on what u need and what to do, but for now this is what im doing.
what i started with
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/spacer%20mod/2009-10-14121502.jpg)
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/spacer%20mod/2009-10-14121532.jpg)
what i have done so far.
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/spacer%20mod/2009-10-14143519.jpg)
only for looks, like the cleaner look with no tabs. still got to add a few more goodies to it and it will be ready to get installed.
what i started with
3.5 psi
StreetKA, it's hard to even understand what you're trying to write. Take your time when you post and make it understandable english please.
The spacer is used on the MDX, Odyssey i believe. It's supposed to increase torque for those larger vehicles, but it's tight in the CL. You can trim your hood and raise the back of the hood a bit to help clear, or like Rajca said, machine the spacer down a bit. It measures 40mm (1.57").
so part #s I'm guessing:
2001 MDX spacer, intake manifold part# 17108-PGK-A00
9 extra long bolts to get it on.... not sure of the part number on that.
just a quick run down of parts and #s would make everyone happy for now.
3.5 psi
^open your hood and look up. You'll see the underside of the hood has metal braces that run down and across it to keep it ridgid. You can cut out a section of the center brace that would be right over the intake manifold. And you can add spacer washers where your hood bolts to the car to elevate it a bit.
3.5 psi
Rajca, when you removed the tabs and all that on the spacer to clean it up, was that just for looks? You could just leave them right...not like you'll see the spacer anyways. Why are the tabs there anyways??
Whats up with RDX owners?
Fuck the hood. You dont need it anyway.
Sorry man. Its a habit I cant shake. (going off topic that is)
