Intake?
SleepinCLS
Intake?
Hi everyone. I'm kinda new to Acura Zine. Ive been a member but barely know how to use it. But I have a 2001 Acura CL Type-S and I'm not sure what kind of intake to go with. I want to hear it from people from Acura Zine rather than some guy from a hooka bar. Haha.
Should I go with AEM, Injen, etc...? Also why u think so.
bye Acura, hello Toyota
Welcome to the site! By the way, where are you located?? As for the intake issue, I agree with Excelerate and say go with Comptech, of course that's only my opinion because it all falls on you as far as to what YOU want to install...PEACE!
In the Mid-South meow
I loved my AEM CAI, you won't be disappointed.
I have a friend that his dad made me a SRI intake with a KN filter. If you want to have a good reasonable priced intake system, I would go with the SRI(Short Ram Intake system.) I think it was the best way to go right now overall, and can tell a nice bit of HP increase. You will have people on here completely disagreeing with my opinon but the friends dad that did mine has a new GTO and just recently added a SRI to the 6.0!!! It's all prefrence what you go with, I think about it this way if you are thinking about doin a supercharger or some major overhaul why not just save the cash to do that nice mod later??
Originally Posted by fuzzy02CLS
Since there are 3 real CAI options made for the car I see no reason to "make" something.
I have a "made" SRI on my explorer cause there isn't 1 made for my X. But the gains are no where near the gains of a real CAI.
I would think a CAI would add more then 2hp over a SRI since the filter is out of the hot engine bay & near the bottom of the bumper when cooler air would be coming from. Colder air = more power.
It's not I totally disagree with you, but there are real CAI options made for the CLS. If your going to mod it you should do it right with parts made for the car, & not "rigging" anything.
And again if these parts are not made for the car Like with my Explorer, then yeah "rigging" something to work to some degree is fine.
I've done it on a number of cars. And honestly I did see a small difference, but I saw & ton of a difference in a real CAI.
But again it's my opinion.
The big difference is when the car is moving because then you're sucking in all that air under the car. I had both a Weapon-R SRI and an AEM CAI on my CL-S and the AEM not only out performed it, it didn't make that annoying humming noise that a SRI will make. Save your money on experimenting with a SRI and get a true CAI, it's totally worth it.
Trolling Canuckistan
Unless you live down south like SuperTrooper169, you may want to avoid a CAI, you run a much higher risk of sucking water into the engine. If I lived in the desert, I would have gone CAI, but I live in New England to much risk for me.
No you don't. That's a BIG scare tactic. You need to submerge the filter in water completely to get it to suck it up. You should not be driving through water that deep to begin with. Splashes, rain, & even some wake while driving through some water will not do it.
However you can get a bypass valve for the intake or get the Icebox since the icebox does not have any sort of threat of water damage.
Former Sponsor
I try not to recommend the bypass valve though for a few reasons. One it really isn't necessary as stated above. Two, you have to cut the intake pipe. Air follows the path of least resistance so it will actually interrupt air flow and cause you to lose a couple hp. Three, they fall apart. They aren't made very well and need to be replaced every couple years from what I have seen.
I don't recommend them but it's up to you. If it helps you feel more comfortable then get one.
Uses turn signals in my
Originally Posted by Excelerate
You would have to drive through 2-3 ft of water to suck up water. You shouldn't do this with any intake, aftermarket or OEM. And Comptech has a flap as Fuzzy said so that it won't suck up water.
You all couldn't have said it better. Comptech if you're THAT worried about hydrolock or a true CAI if you're realistic. My buddy ran an AEM on his Celica GT-S back when we both lived in Connecticut and he said he ran it through not only rain, but deep snow as well and never had a problem. True I have it good being in the desert, but when it rains it pours here, so there's more of a chance it'll flood here and have huge deep puddles.
EDIT: Just bought an AEM V2 CAI for my Accord.
SleepinCLS
Now do u guys recommend Fujita, AEM, Icebox or Injen? If u guys gimme reasons too, that will be great. The reason y i say Fujita is b/c my friend with the new TL said Fujita has really good intakes for CL-S. Im lookin for the most gains and a really nice humm/sound.
'99 AV6. :D
http://www.youtube.com/watch?v=JJxWueCDKTo
http://www.youtube.com/watch?v=MROOcHv5qLw
Those are two videos I just took of my Fujita. enjoy. one is windows up, the other is windows down.
SleepinCLS
Originally Posted by thevikas87
hey, hookahs are the shit
what kinda tobacco you using?
that is...if you're using tobacco....?
oh and im saving up for an AEM
I too live where there is lots of water and was worried about a CAI..but didn't want a SRI because of the sound and lack of performance. I had one and it sucked (no pun intended). Anyways i removed my res dropped in a K&N and made a tube with a slit in it to fit on the bottom of the stock air box so the cold air from under the car is pulled up but water splashing won't (Very similiar to Comptechs design but no need for a flap to stop water..just custom alum. tubing and a little common sense). I've been in some really heavy downpours and even some slight road flooding and had no problems what so ever.
Plus from the engine bay...everything looks stock.
Good luck
Good luck
Well...it's kinda fast...
Good luck
Good luck
Only CL in town!
go search around the black market. Excellerate has se good deals on cais. There is nothing wrong with the cai, the sound is good, performance is great, and no problems with water. Just dont drive through 2 or 3 feet of water. If you are going through some water that you are scared of, just dont accelerate, just cruse through the water
Originally Posted by sailojai
Ive been searching and could not find anything about this. 01-03 Acura CL 3.2L Type S
Weapon-R Secret Weapon Air Intake System
Is that any good? I just got my 03 CL typeS 6speed yesterday.
I want intake but dont really want CAI
If you have a 6 speed, the one they make for the CL type S won't fit. The automatics have an extra piece on the throttle body for the VSA system which us 6 speeders don't have. What you need is the piping from an Accord V6, it's about 6" longer before the bend.
DON'T BUY IT FROM ERZ PERFORMANCE, THEY DON'T KNOW ABOUT THE PRODUCTS THEY SELL. That's why I had to modify mine for clearance.
The folks over at Weapon R were very helpful.
140,000 miles young
Love my CAI (injen). Better performance (and sound in my opinion) than a short ram, and unless you are really really really stupid you won't have any water-in-the-engine (hydrolock) issues. There is a reason they don't market Short Rams to the type S - the power isn't there.
around my area theres a lot of flood issues. Would there be a problem if i was to start up my car when its already in the flood? my drive way sloops down and sometimes the water is up to the level of the door.
I am BIG NOOB.
I am BIG NOOB.
"Water is up to the level of the door" ????
Sounds to me you need to buy a jeep with a snorkel damn!
Holy crap...CAI is out of the question for you.
Well with that in mind. I dont think its a good idea for me to get CAI. am I not correct?
AcuredCLS
i would go comptech, im savin up so when winter is over im replacing my headers and intake with some comptech. i know everyone is about the sound, but i like the way a car can perform and comptech is $$$ alot of $$$$ but its the best...
