Installing SPC control arms?
Old 09-17-2005, 09:39 AM
Not Asian
phipark's Avatar
How difficult is it to install these on your own? The dealership quoted me $120 per side, which I know is insane. Won't I need a special tool for the ball joint? For that much money I'm tempted to do this on my own. Any good DIYs out there for this?
Old 09-17-2005, 10:30 AM
Not Asian
phipark's Avatar
Nevermind, found them.
http://www.cardomain.com/ride/184466/15
Old 09-17-2005, 09:09 PM
Blown is Best
Allout's Avatar
On the fronts, I just used my bench vise and improvised. Not too dificult at all.
Old 09-17-2005, 10:14 PM
Parting out 02 Type S :(
power3dfx's Avatar
if i were to get this control arm, would it cure my inside tire wear? on the front drivers side tire, the very inside of the tire gets at least 50% more wear than the rest! it has ate up 4 tires in 2 years so far, and its driving me nuts! i never had a problem when i was stock. would i be able to adjust the camber with this control arm so that this would never happen again? also, can i just do one side? I dont have much camber issue anywhere else.
Old 09-17-2005, 10:58 PM
Blown is Best
Allout's Avatar
It should give you enough adjustment to correct your tire wear problem. I would do both sides so you can get a good adjustment.
Old 09-18-2005, 05:50 PM
Not Asian
phipark's Avatar
Old 09-20-2005, 04:37 AM
power3dfx's Avatar
my friend was saying something about caster camber plates which he has on his mustang. they are supposed to give 4 way adjustment. this control arm would just adjust for camber right? i dont think i can get them seperately anyways, but i would if i could because i really just need it on one side!
marcelft
07-10-2018 06:17 PM
james357
02-13-2016 02:37 PM
Aging-Hacker
10-05-2015 11:44 AM
gqdabien
09-08-2015 11:41 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Installing SPC control arms?
