Installed the M6's - looks great..however...
2002 CLs w/Navi
I installed the M6 fog light bulbs, they look 100 times better. However, after a week I have notice some discoloration on the top of the bulbs, they have a slight burnt color on the top part of the bulb. Does anyone else notice this. The inside of the fog light is ok,, no burning there.
Re: Installed the M6's - looks great..however...
Where'd you order yours from. Seems my order from a previous company NEVER came through ???
Cost Drivers!!!!
they'll burn out and by the time it happens they'll have formed a bubble, then it'll be hard getting the bulb out because of bubble. When i had my auto i just ended up taking them out.
Yeah, they just do that. And as Zapata said they will likely bubble a little before they die.
Then you'll have to break them up and shake out the pieces.
I've gone through 2 sets so far. They tend to last about a year or so for me.
But they're worth the little bit of trouble they cause as far as I'm concerned.
You also might notice the top of the housing will eventually turn a little brown, but it will typically wipe off, and even if it doesn't, it's not like you can see it anyway.
Is there a BULB close to the M6 in Light Intensity, Closer to the size of Stock that Might be a Good Choice for those looking for a little more BULB life, yet more Light than the Stock ?
Xe- For Better Hwy Vision
...and what ever you do Don't Touch the Bulbs with your exposed fingers. Oils from the skin will coat the bulb and generate undesired heat gain = premature lights OUT!!
$.02
$.02
Yeehaw
Re: > ?
I got the PIAA's, no problems.
2002 CLs w/Navi
I have had them installed for a week or so, no burning yet on the top of the fog light..... just a little burning (brown) on the top of the bulb... They still look great. Also.. I run my headlight's 24x7.. so I'm sure they won't last as long for me. Is there a way to turn on the headlights without the fog lights on? can I remove a fuse or something ??
Re: Re: Installed the M6's - looks great..however...
cnyautoconcepts@yahoo.com
Another consideration are the new LED bulbs that PIAA makes if your worried about longevity. I have them in mine. They are brighter than stock or even the other 5w piaa bulbs, they are probably not brighter than the 19224's that are 18w. They do come in three colors; white,blue/white,and blue. Since they are LED they have a cool percise beam to them. By the way i have the white ones
Re: Re: Re: Installed the M6's - looks great..however...
Yep: Except MY order NEVER came in
Originally posted by flint
You ordered yours from CNY when I did didn't you? It took like a month but I got mine. They said their supplier was out.
Beware of leakage
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
