Installed Icebox and have problems.
Old Aug 23, 2005 | 11:40 AM
Sun Diego CL-S's Avatar
says "hello to my TLX".
i just installed the icebox yesterday and now i'm left scratching my head. when i accelerate, it really feels bogged down. i have already driven it for about 2 hrs. so the ecu should've already read the change. after the last spin this morning, i got back home and it really started doing this noticeably bad idle that u could see on the tach and hear the muffler sputtering.
one thing i do know i didn't do is replace any coolant. i spilled quite a bit but then the radiator looks full. all connections have been triple checked. your advice is appreciated.
Old Aug 23, 2005 | 11:51 AM
typeR's Avatar
sounds like you have a vacuum leak ...your idle will bounce in the ecus effort to control the idle rpm...i would check things like make sure there was no packing meterial left in the cone,and that all the lines are re connected if all else fails try the idle learn procedure
Old Aug 23, 2005 | 11:56 AM
the one step i will do again is dis- and reconnect everything. and what is this idle learn prcedure?
Old Aug 23, 2005 | 12:09 PM
typeR's Avatar
look in the fliter for packing material and in the tb...the idle learn can easily be searched but basically it's disconnect the neg battery terminal 15 minutes is good...hold at 3k until both fans come on then allow to idle...not 100% but do a search,been covered many times
Old Aug 23, 2005 | 01:02 PM
scalbert's Avatar
This may seem like a stupid question but you never know. Did you remove the plastic from around the filter?
Old Aug 23, 2005 | 01:03 PM
scalbert's Avatar
A vacuum leak wouldn't nessesarily cause an issue under load. Normally it is just at idle or high vacuum situations. Under load there should be close to no vacuum.
Old Aug 23, 2005 | 01:44 PM
i didn't remove the plastic. haha, why of course!
oh and thanks to type r for mentioning the idle procedure. i searched that bitch and got tons of answers i didn't find before. that seems to have worked. hopefully other noobs will read this and not post these kind of ?'s for a while.
Old Aug 23, 2005 | 06:37 PM
SG81's Avatar
Missing My CL-S
Old Aug 24, 2005 | 05:14 PM
has anyone else experienced their car shift before redline between 1st and 2nd? normally on WOT, it would reach the redline, but now it just reaches 6,500 rpm.
Old Aug 24, 2005 | 05:15 PM
typeR's Avatar
when you reset the computer that will happen...go WOT a few times and shifts will come later and later
Old Aug 24, 2005 | 08:51 PM
scalbert's Avatar
Undocumented adaptive shift algorithm.
Do what typeR mentioned.
BadassAcuraCl
1G CL Problems & Fixes
Sep 14, 2016 03:26 PM
Nitin
Sep 30, 2015 08:22 PM
TxRzrBk
Sep 17, 2015 01:07 PM
HydrasunGQ
Sep 14, 2015 10:14 PM
Leester01
Sep 11, 2015 06:35 PM
