installed the door handle led
Chapter Leader (NY/NJ)
excpet it only turns on when i open the door.. how can i have it to turn on w/ just using the oem factory alram, when u unlock and lock the car? where would i wire it to? thanks, ill post pixs of what ive done so far this wknd.
i did wire it to the door lights, i thought it would trun on. there were so many wires and it was late and dark, had to ahve my friendput his car behind mine and leave his hid lights on,lol
anyways, where would i find the dome trigger wire? and do i need to get a fuse and must i disconnect batter first too? thanks
ok cool, i was just wondering if anyone else have done it to their cl too. so does all the wiring and the fuse boxes are the same as the tl's? thanks again.
Received 1,080 Likes
Pull the dome light down and look at the wiring colors. Then climb under the dash and find them.
Or you could run wire all the way up in the headliner and tap them at the dome light.
Good luck feeding wire through the door grommet.
so is the dome light the only way to go, if i want the door led handles to light up when i unlock and lock the doors, the dome is the only way to tap the wires into? any where else easier? thanx. so the stock alarm cant be helpful to it?
Well if you want the door leds to light up and stay lit when you open the car, it has to be to the dome light. They will shut off after a short period if you don't open the door. That's the only thing that turns on when you unlock. And when you lock I don't believe anything will happen.
no someone told me to go into the fuse box and look for the dome wires that hooks up to the fuse and tap it from there and install a amp relay as well.
Unregistered user
i'm just saying its really not that hard. basically you want it to turn on when you unlock your car right. what else turns on when you unlock it? your dome light. basically it sends electricity to the dome. thus if you tap into that wire once the dome goes on your door handle light goes on.
i believe the dome light has a fuse, thus you don't need it, all you need is your led and the proper resister soldered on, buy some wire and tap it. its simple but takes a long time.
'03 ABP YA4-S 6MT
Originally Posted by LUTHOR-CL
oh can i go through using the stock alarm? where may i find that to relay the power from there? thanks
Originally Posted by rp_guy
honestly do you even read what other people say ?
rockyboy
08-04-2024 10:35 AM
tman570
06-11-2019 07:56 AM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
