Install in progress (low CR, boost,IC +)
BTW, last night I tested the CL-S injectors at WOT with REAL TIME e-manage screen and it looks good
. Just need to resolve fuel issue up top (still lean) but retard timing helps so it's safe
Here is the data:
Still have room to go
Here is the data:
Originally Posted by Excelerate
I hope you're enjoying your new parts.
Josh
Excelerate LLC
Josh
Excelerate LLC
. The car now has the stopping power and doesn't squat at all when accelerates from the line.
Serge, got to get you a piece of black vinyl for the rear window dot-matrix.
where did you find those upper rad support pieces?.. the shiney supports!
Also I am having a minor PnP problem right now.. I will push numbers back and forth with you after I get it resolved in about 2 weeks.
Radiator holders link
Most important is to keep wires connected especially the RPM (was disconnected, thus delay occured). Sounds good, I would be curious to compare with your maps.
I've got those bfg kdws on my tl and I love them. The are great in the dry and awesome in the wet, stick like glue. They are a little noisy at highway speeds 75+, but well worth it for the grip.
cool thanks.. i ordered them.
Yeah I am not having connection probelsm with the RPM.. it is one of the lines to the injectors. Scalbert will fix it in a few weeks after his vacation.
i compared the radiator holders on my '03 TL-S to a 6th gen Accord. the ones on my tl-s are taller. they do, however, work for the '99-'01 TL. so unless, you have the shorter radiator holders, the wont work.
my tl-s
__
....l
....l_
accord:
__
....l_
make believe the periods arent there.
YOU mother fookin HOnkie Steve.. I am going to bury you upside down.
I do belivethe only diff between the CL-S and TL-S rads are the fan shrouds.
I sent them an e-mail cancelling the order....
i'll try to take a pic in a few mintues of my rad. holders so you can compare.
They work on mine but part of the plastic trim that is in the front of the car covers half of it. Here is a pic of the holders after I got them rose nickle plated. I tried them before I plated them, so they work. bling,bling
I'll take a picture of them tomorrow on the car.
http://pg.photos.yahoo.com/ph/trlloy.../ph//my_photos
Originally Posted by Louie11
Great job
The car looks incredible
Where did you mount the EDFC? Those lower pics look as if they were taken at the shopping mall off of Willow rd. west of waukegan rd.
Where did you mount the EDFC? Those lower pics look as if they were taken at the shopping mall off of Willow rd. west of waukegan rd.I used velcro to mount EDFC on the top of my wideband in the center (see below)
And correct on the shopping mall
Originally Posted by mrsteve
How do you like those BFGs you have mounted up front?
So glad I made this choice, plus it was special for these 225/45/17 - $125 (each).
As you noticed rear ones are Sumitomo HTR Z II and they fine, however BFG KDW 2 is clear winner, thus I get them on the front and might utilize on the track in the future. In fact, I know bunch of guys who swear they deliver exactly the same results as new Michelin Pilot Sport SP2 which is more expensive ($176) top rating max summer tire.
BTW, I already mentioned the testing last night with wideband and believe gained some power
(soon going dyno to conclude).
Ran the car with wideband recording data and broke it down the results starting with 3800rpm - 5500rpm. My previous dyno showed torque dip between 4-5K rpm and going strong right after. So after analyzing the results (showed drop from 10.8-10.0 AFR), I pulled some fuel on Injection map. Ran the car again and liked better pull with 11.6-11.0AFR.
So will be tuning more soon, especially on dyno.
(soon going dyno to conclude).Ran the car with wideband recording data and broke it down the results starting with 3800rpm - 5500rpm. My previous dyno showed torque dip between 4-5K rpm and going strong right after. So after analyzing the results (showed drop from 10.8-10.0 AFR), I pulled some fuel on Injection map. Ran the car again and liked better pull with 11.6-11.0AFR.
