IMPORTANT Icebox install question:
Old Dec 21, 2010 | 08:00 PM
Jacobpockros's Avatar
I'm currently in the process of instaling my icebox and I am now in a snag. I need to know where I am supposed to connect this hose under the throttle body:
Does it connect to this!??
I need to know! Thanks. -Jake
Old Dec 21, 2010 | 11:26 PM
progression's Avatar
Did you take that off or was it already off? it looks like it is the throttle body coolant line.
Old Dec 21, 2010 | 11:33 PM
I didn't take the hose off in the first picture, it's still dangling. I fully disconnected the hose in the second picture at the end of the throttle body though.
Old Dec 21, 2010 | 11:48 PM
CH46ESeaKnight's Avatar
Congrats on finally getting it.
Since you live in SD, you could likely get away with a Coolant bypass. Its a very popular mod in warmer climates and will give you some gains (or more like freeing up) by not heating up your throttle body. You should look into it.
Old Dec 22, 2010 | 12:06 AM
I just want to do it the proper way. I need some more responses here! I cannot drive the car till it's finished.
Old Dec 22, 2010 | 12:54 AM
cu0ngsayz's Avatar
http://lishutterbug.com/acura/cai/
look at those pictures... cant really see from your pictures.
Old Dec 22, 2010 | 01:00 AM
you can either re connect it or bypass it.....take a look at this thread https://acurazine.com/forums/showthr...coolant+bypass
Old Dec 22, 2010 | 01:50 AM
I want to do it how Comptech did it. The link that cu0ngsayz posted doesn't show exactly what needs to be done.
I need to know where these two things connect to:
I have one hose left....
Do I just connect them together with the hose?
Old Dec 22, 2010 | 01:57 AM
Looks about right to me. If you have one hose and two fittings left? Seem right that the coolant would come out of the throttle body and back to the block. or the other way around.
Old Dec 22, 2010 | 02:54 AM
^ Okay, thanks for the input .
Now can someone else conform this so we have more than one confirmation just to be safe?
Old Dec 22, 2010 | 03:30 AM
i dont see why you needed to take off the throttle body coolant line to install the intake in the first place. Im thinking the hose you got with the intake will connect directly into the intake piping where those two outlets are from the valve cover to the intake. i could be wrong tho..
Old Dec 22, 2010 | 03:34 AM
This is the hose that connects to one of the two intake outlets:
Then, the big breather hose from the valve cover connects to the other outlet, which leads me to believe that the following get connected to each other:
Old Dec 22, 2010 | 03:46 AM
ok as long as its all connected your fine. Im not sure what the kit came with but i would assume that it probably came with two hoses...both for connecting into the intake outlets, leaving the coolant lines as they were to begin with.
Old Dec 22, 2010 | 04:02 AM
Not exactly. One supplied hose goes to the outlet, and the other outlet gets taken by an existing hose. The second hose that is supplied most likely gets used to connect the two coolant outlets that I pictured. This is what you guys originally suggested and I think that is correct.
Old Dec 22, 2010 | 08:45 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Old Dec 22, 2010 | 10:48 AM
NSXNEXT's Avatar
Is there coolant coming out of the lines that are disconnected?
If so, go to the auto parts store and get a hose coupler.
Old Dec 22, 2010 | 11:39 AM
SexyCLS's Avatar
Originally Posted by 97blackackcl
+2
Old Dec 22, 2010 | 12:12 PM
You guys suck lol
Old Dec 22, 2010 | 12:13 PM
....so do they get connected to each other?
Old Dec 22, 2010 | 12:40 PM
civicdrivr's Avatar
The 90* fitting near the inlet of the TB is a for a coolant line.
Old Dec 22, 2010 | 12:51 PM
But where does the coolant line connect to? What do I do with the other fitting to the left of it?
Old Dec 22, 2010 | 12:59 PM
civicdrivr's Avatar
Im having a tough time seeing the other fitting, but if its on the block (technically the coolant pipe), the fitting on the TB connects to it.
Why did you disconnect those and didnt any coolant pour out?
EDIT - Give me 5 minutes, Im going outside to take a picture of mine for you.
Old Dec 22, 2010 | 01:19 PM
StreetKA's Avatar
+3
Old Dec 22, 2010 | 01:25 PM
Originally Posted by StreetKA
+3
This is getting too funny
Old Dec 22, 2010 | 01:28 PM
Because CT instructed me too:
Old Dec 22, 2010 | 01:31 PM
StreetKA's Avatar
It does but come on its one of the easiest mods to do. Just look at it and figure it out.
Old Dec 22, 2010 | 01:41 PM
civicdrivr's Avatar
Ok, I forgot about that part. Its been over 2 years since I installed it. I hope this makes a bit more sense. I am going to show how the connections go from factory.
Look at the hose marked number 2. One end of that hose goes into the 90* fitting near the inlet of the TB. It then goes into the hard line (that CT has you remove). It loops into the hose marked number 3.
Hose number 3 runs into the green arrow marked below. The hose in the above picture marked number 1 goes from the fitting on the IACV (bottom of TB) into the red arrow below.
If you want to do the coolant bypass, just loop the line between the red and green arrows as seen in the picture above. You can keep leave the two connections on the TB disconnected.
And yea, my 5 minutes morphed into 40. Whatever.
Old Dec 22, 2010 | 01:47 PM
Originally Posted by Jacobpockros
I just connected these two fittings with the hose that CT gave me. I think that's what it was intended for
Old Dec 22, 2010 | 02:12 PM
Almost done. Is this unconnected hose a vacuum line?
Old Dec 22, 2010 | 03:07 PM
civicdrivr's Avatar
Yes.
This is turning into a 19 hour intake install
Old Dec 22, 2010 | 04:32 PM
Finally done! Everything is where it should be. Thanks guys!
Old Dec 22, 2010 | 04:40 PM
cu0ngsayz's Avatar
hahahah a 24hr intake install lol... but on the good side you got it done
Old Dec 22, 2010 | 05:56 PM
typeR's Avatar
is it too late to tell u that if you take out the battery and battery tray its was easier ?... lol...
or wait ... if u did that ud wanna know what to do with the red and black battery terminals afterwards ...
Old Dec 22, 2010 | 06:50 PM
Rapture's Avatar
Wow, is the Icebox install harder than the Injen CAI install? I remember the instructions were pretty straight forward with that one. The hardest part was resonator removal + getting the filter over the pipe, and getting a few of the hoses off for the coolant bypass.
Old Dec 22, 2010 | 07:03 PM
Well wait a min, which line takes the cold coolant to the actuall IceBox to cool the intake? Better check it again Jacob! I heard if you run the IceBox dry it will burn up and start melting right away!
Old Dec 22, 2010 | 07:57 PM
The coolant lines don't connect to the icebox.
Old Dec 22, 2010 | 08:01 PM
No man they don't, I was just messing with ya!
Old Dec 22, 2010 | 08:12 PM
oh haha. You had me worried there though
Old Dec 22, 2010 | 08:29 PM
cu0ngsayz's Avatar
hahah lol epic
Old Dec 22, 2010 | 09:48 PM
I think this intake install went worse:
https://acurazine.com/forums/acurazines-hall-fame-284/aem-cai-installed-took-my-11-yes-11-fukkin-hours-aka-turny-clicky-thread-406040/
