The importance of a oil catch can
Old 02-11-2010, 06:59 PM
  #121
OG 3.x^7 rawr
SPoolinspOON's Avatar
it's an oil catch can for crying out loud...lol
As long as it works and looks decent
Old 02-11-2010, 07:10 PM
  #122
lowrd on tein CS biatch
CL-S progression 01's Avatar
yea but have u seen my engine BAY...
I have standards to keep up
High standards
Old 02-11-2010, 07:15 PM
  #123
B A N N E D
friesm2000's Avatar
f***ing shit, my post from a couple of hours ago did not post
but anyways, as long as they fit they will work (proably better too, cause being larger, it allow that oil that much longer to seperate from the air
also they would require less frequent draining also
Old 02-11-2010, 07:24 PM
  #124
look at post 115.... u did post it :-p
Old 02-11-2010, 07:30 PM
  #125
B A N N E D
friesm2000's Avatar
, thought it was after the hondabond comment from civic
Old 02-11-2010, 07:35 PM
  #126
wham bam thank you ma'am
Rajca's Avatar
just get one. then two T fittings and ur set to go. they dont fill up fast at all.
Old 02-11-2010, 07:54 PM
  #127
rajca that's cause ur motor is running good.
I have a feeling, how fast they fill up is a good indication of the motor's condition/how hard (the driver is driving it).
so the slower the better :-) IMHO
Old 02-11-2010, 08:04 PM
  #128
Rajca's Avatar
Funny thing u say that. i ran out of oil today on the way home from work
that little light was blinking so i pull over and check teh level. just barely shows on teh dipstick
pour in 3 quarts of oil all good. but the oil is black. never see it that black before in my life in any car that ive worked on (or truck). damn bent valves. still beat the shit out of the car.
Old 02-11-2010, 08:08 PM
  #129
B A N N E D
friesm2000's Avatar
then no freash air can get into the motor as needed, but yeah mainly just needs one off the back valve cover/pcv and that will proably cut out 98% of the oil or more (front vavle cover one should just be letting in freash air anyways)
kinda, but also can be how crappy of oil you might be using
also how is his motor running good with bent valves
Old 02-11-2010, 08:22 PM
  #130
Rajca's Avatar
no, front one doesnt let fresh air in. works just like the rear one . so, run a hose from the front valve cover to a T then from the rear valve cover to the same T then from that T to the catch can.
then
from the catch can to a T and from that T one hose to the front valve cover and one the the back. all done. does the job of two catch cans. and saves u money
Old 02-11-2010, 08:36 PM
  #131
B A N N E D
friesm2000's Avatar
then
actually it won't work correctly, part of the reason for them going to seperate places on the intake (aka one behind the tb, and one before) is to help maintain the circulation of air throughout the engine
Old 02-11-2010, 08:38 PM
  #132
Rajca's Avatar
ones goes right before the tb and one goes into the intake manifold plenum. both do the same
and. same oil vapors in the front plenum as in the rear one so u wont have a problem.
Old 02-11-2010, 08:44 PM
  #133
i don't get ppl who put only one catch can on tho. my2cents
Old 02-11-2010, 08:47 PM
  #134
Rajca's Avatar
bc u dont need more than one. save the money and spend it somewhere else. i got a small $7 or so breather on my front valve cover and gonna be putting one on my rear valve cover.
Old 02-11-2010, 09:07 PM
  #135
B A N N E D
friesm2000's Avatar
ones goes right before the TB and one goes into the intake manifold plenum. both do the same
ummm... front one gets it's air basically from the atmosphere (obviously through the air filter first though)
and the rear has vacuumed applied to it, especially under engine braking (actually any time the TB is partial closed, there is a vacuum applied to it; even at WOT throttle there will be an ever so slight vacuum at it because of the TB causing a slight restriction), also the PCV is basically a check valve with a metered orifice for the correct amount of crankcase vapours for the motor
Old 02-11-2010, 09:13 PM
  #136
ok so I am going to get one or 2 or ZERO catch cans??
wtf is the BEST
Old 02-11-2010, 09:16 PM
  #137
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,450 Likes on 4,972 Posts
One
Old 02-11-2010, 09:22 PM
  #138
B A N N E D
friesm2000's Avatar
One
x2, two is kinda pointless
Old 02-11-2010, 11:29 PM
  #139
ok so then I just do the rear one or what?
what's the "proper" way
Old 02-11-2010, 11:39 PM
  #140
B A N N E D
friesm2000's Avatar
yes the one with the pcv valve which is the rear one, basically you just reroute the line through the catch can, and route it back to the origional locations and you are done, after you mount the can of course
Old 02-11-2010, 11:43 PM
  #141
k but why only one side??? (I had to ask)
don't both valve covers put the same amount of oil vapor back into the motor?
Old 02-12-2010, 12:20 AM
  #142
aznboi2424's Avatar
rubber cork ftw!
Old 02-12-2010, 04:20 AM
  #143
Rajca's Avatar
Originally Posted by aznboi2424
rubber cork ftw!
i hope ur joking
u wouldnt want to plug up the vent. but hey, its ur car do what u want
Old 02-12-2010, 11:04 AM
  #144
so is anyone going to explain WHY i should only do ONE catch can and not two?
and why I should only do the rear valve cover and not worry about the front cover.??
plz and thank you
Old 02-12-2010, 01:39 PM
  #145
aznboi2424's Avatar
i hope ur joking
im still stuck on fixing my inline filter
Old 02-12-2010, 02:55 PM
  #146
B A N N E D
friesm2000's Avatar
plz and thank you
some people actually work here, unlike some people
as said earlier the front vent only supply freash air to the engine, so oil should not be coming out, so the rear one only is needed
just use some rtv sealant already
Old 02-12-2010, 03:17 PM
  #147
^^ thank you for the clarification
Old 02-12-2010, 03:22 PM
  #148
B A N N E D
friesm2000's Avatar
^np
Old 02-12-2010, 03:40 PM
  #149
Rajca's Avatar
its a valve cover theirs gonna be oil under it. oil gets hot, than u have oil vapors, those vapors will get sucked into the engine. u need to do something about the front one also.
Old 02-12-2010, 03:46 PM
  #150
civicdrivr's Avatar
Ive honestly never seen any oil come out of the front VC vent. Only the rear PCV.
Old 02-12-2010, 03:58 PM
  #151
B A N N E D
friesm2000's Avatar
see civic's \/, by design it should not be coming out of the front vent anyway
thank you
Old 02-12-2010, 04:04 PM
  #152
civicdrivr's Avatar
Rajca, you have the front VC vented to atmosphere right? Have you noticed any oil in your breather filter? If not, then you definately don't need the catch can on it.
Old 02-12-2010, 04:09 PM
  #153
Rajca's Avatar
havent noticed anything. but than gain. it doesnt have any vacuum to pull the vapors out of the vent and into the engine. i know ppl that run breathers on their engine and have no oil whats so ever come out. and not only on v6. i4 and v8 (race engines)
Old 02-12-2010, 04:14 PM
  #154
B A N N E D
friesm2000's Avatar
there should not be any vacuum being pulled on that vent anyways (except internally inside the motor), even when connected stockwise, the reason for it being before the tb
Old 02-12-2010, 06:39 PM
  #155
Rajca's Avatar
so when the car is idling or driving or WOT. its not pulling any fumes? bc then the engine wouldnt pull any air if that was the case. unplug the hose that goes from the intake to the valve cover, if u get suction where u unplugged the hose, it pulls some fumes from the valve cover. might not be as much as the rear. but still does
another question, why have a vent on teh front valve cover????? theirs got to be a reason
Old 02-12-2010, 07:18 PM
  #156
B A N N E D
friesm2000's Avatar
because other wise you would pull FULL manifold vacuum at idle, and probably pull all the seals inward
but also you gotta be able to exchange all the air in the crankcase at some point eventually
and try covering the pcv valve hose with your finger with it idling, will be a good vacuum then, and as said the pcv valve is a metering orifice for the vapors, so the reason for the lower vacuum at the front valve cover, never able to pull full vacuum on it
Old 02-12-2010, 07:44 PM
  #157
So...having a breather on the front isn't necessary then if it's just sucking in air from the intake.?
I would put a breather on, but then I got an open pipe coming from my shiny intake and I don't like that jazz.
Old 02-12-2010, 07:58 PM
  #158
B A N N E D
friesm2000's Avatar
now if the pcv happens to get plugged (or just plugged enough), you might get oil out the front vent then, but yeah you should never be getting oil outta of that front vent
and what do you mean by a "open" pipe, it needs to have some type of filter to prevent dirt from going in there (be just like pouring dirt into your oil fill port, just slower though)
Old 02-12-2010, 08:07 PM
  #159
i mean the open "spot" coming out of my intake pipe.... right?
cause if i just slap a filter onto the valve cover, Ill have the side on the intake with nothing attached... which is goofy if you ask me, plugging an orifice or having too many. just isn't my preference
http://cgi.ebay.ca/Simota-Red-Oil-Ca...item414cf1851f
Don't outbid ME! lol
it'll get messy
Old 02-12-2010, 08:10 PM
  #160
Rajca's Avatar
plug it up with a rubber cap or something.
Quick Reply: The importance of a oil catch can
