Impact Wrench
Old Apr 2, 2004 | 09:36 PM
ChadT's Avatar
Spectacular Aroma About
Impact Wrench
I finally got to try out my Ingersol Rand Titanium impact wrench. I used it to change the wheels. It takes about 1/2 of a second to fully remove a lug nut. It's awesome! You just pull the trigger and before you get it pulled all the way the nut is off. I also used it on the A-pipe and cat bolts when doing the headers. It took all of about 20 seconds to remove the 9 bolts on the a-pipe. I also used it to put the wheel lugs back on. I had it on the lowest setting for that and just kind of tapped the trigger and let it coast to drive the nuts on. It worked out perfect as I only had to turn the bolts 1/8 turn or so to get them to 80 ft lbs with the torque wrench. The wrench also doesn't use much air becase it barely gets a chance to run.
Old Apr 2, 2004 | 10:03 PM
Chemmech's Avatar
Chad T, the official Acura CL Tool Guy .
Old Apr 3, 2004 | 01:53 PM
NSXNEXT's Avatar
I'd be afraid of scratching the wheel. I've seen too many wheels that are all marred up where the lugs go from impact wrenchs.
Old Apr 3, 2004 | 03:25 PM
SiGGy's Avatar
Moderator Alumnus
Ya, and I would never use an impact to put the wheels back on. I have a nice clicky torque bar I use for that. On some wheels clearance between the socket and hole isn't much.
Old Apr 3, 2004 | 03:32 PM
dallison's Avatar
registered pw
impact was awesome when i had to loosen up the bolts on my struts and contrl arms on my camry
Old Oct 2, 2006 | 04:32 PM
labelhunter's Avatar
Holy old thread but i have a question of what kind of compressor would i need for a wrench like that?
Old Oct 2, 2006 | 05:07 PM
cltypeSLOW's Avatar
Don't Mess With Texas
an air compressor :captainobvious:
Old Oct 2, 2006 | 05:19 PM
mclarenf3387's Avatar
Depends on the power of the impact wrench, but the bigger the better.
Old Oct 2, 2006 | 05:32 PM
GreenMonster's Avatar
Maybe, maybe not... some are electic...
http://www.amazon.com/DEWALT-DW290-E...7?ie=UTF8&s=hi
I inherited an air compressor when my dad passed, I just need to get 220v wired into the garage... I've been tempted to just sell the 220v and buy a 110 to replace it
Old Oct 2, 2006 | 06:44 PM
CleanCL's Avatar
sell it to titand19, he wants a 220
Old Oct 2, 2006 | 09:25 PM
Do you have any recomondations for a 110 that doesnt weigh all that much. I will have to lug it up and down stairs at my place. I think the wrench calls for 5 at 90PSI
MrHeeltoe
20
Feb 23, 2023 01:54 PM
brboy
Oct 5, 2015 11:34 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
jpadilla
3G RLX (2013+)
Sep 27, 2015 07:53 PM
