If u Gota Hook Up ? Hook It Up !
Also,
Something I learned right away, 4 years ago when I started reading this forum...
You will get more members to read your post if you list the subject of the post in the subject line.....
ie "Axis milano question"
Welcome aboard!
Welcome aboard!
Doin' da crack shuffle
Originally Posted by BBsAcuraRacing
I have a 8" inch wide wheel with a +50mm offset
I could easily go wider, clearance wise
Milano's don't come with a 50 offset and they smallest width is 8.5 inches.
He'll rub for sure.
Spectacular Aroma About
50 offset vs 42 offset (highest milano offset they offer) is a much bigger problem than 8 inch vs 8.5 inch.
____________________
if you are not planning to lower the car then they should fit just fine... (looks weird) but u WILL start having some serious rubbing problems once u drop ur car and especially when u have passengers inside
Originally Posted by Ssaba420
I was Thinking about getting "Milano" From Axis..Does ne`One Have Em On Their CL ? Let Me Check Em Out
AcuraKidd
09-25-2015 11:18 PM
Eggs999bacon
09-24-2015 10:08 AM
