if its 86 degrees and about 90% humidity??
1/4 14.4 at 95
im going to the track with my auto 03 cl-s with aem intake, what should i run with these conditions?? will this heat kill my time? and if so by how much?? has anybody raced with weather like this? and how much slower did they run than the normally do??? any info would be appreciated asap please...
My auto ran a 15.3 in similar weather stock .. you have the intake.. so shave about .1 to .2 off your ET. with that heat, traction should be pretty shitty unless you lower your tire pressure. These engines ... hell, ANY engine, absolutely hates hot humid weather, as you know.
P.S. my trap time was a measly 91 mph .. i lost sooo much time peeling out ... i forgot to lower my tire pressure, so i never hooked up.
Most people accept the fact that you can shave about .4 to .5 seconds off your ET when comparing your hot, humid weather time to a 50 to 60 degree (fall weather) run...
ga, you need to stop talking about the track and start going.
1/4 14.4 at 95
i have a good idea of how mant 10ths i would lose in the heat im just getting other opinions and just to let u know mattg with my last 2 cars i ve been to the track plenty of times
then you should know.
emailnatec
29
09-28-2018 04:27 PM
MonkeyTrucker
12-12-2017 08:59 AM
