idling problem after installing mods
Old Feb 7, 2008 | 10:21 PM
calvinnguy3n's Avatar
after i installed the 3 peice underdrive pulley set, intake manifold gasket, and the throttle body spacer the idle is all messed up. when i'm in park or neutral it fluctuates from 750rpm to 1,500rpm. but when i'm in gear, drive or reverse, it's perfectly fine. any ideas?
Old Feb 7, 2008 | 11:54 PM
BigLizard's Avatar
Moderator Alumnus
tighten up the manifold and TB gaskets more...sounds like a leak.
Old Feb 8, 2008 | 07:55 AM
fuzzy02CLS's Avatar
Or do the idle re-learn procedure. It's outline in the FAQ.
Check your connections
Old Feb 8, 2008 | 07:58 AM
NSXNEXT's Avatar
Leak or your idle air control valve needs to be cleaned.
Old Feb 8, 2008 | 09:46 AM
typeR's Avatar
almost certainly a leak , anything from incorrect install to forgetting that tiny vacuum line near the back of the manifold next to the IAT
Old Feb 9, 2008 | 03:31 AM
i'm pretty pissed off. i found the problem and it was due to the intake manifold gasket. it just wouldnt seal completely. i tightened it enough so the gasket wouldn't crush but it was still leaking at the corner of the gasket. i now have to end up buying another intake manifold gasket for 90 bucks and throwing this p2r one away. what a waste of money and time
Old Feb 9, 2008 | 07:41 AM
Silvaccordex01's Avatar
The P2R one wont crush unless your using an impact wrench to tighten it down. Make sure all the bolts are nice and tight and you should be fine. Several of us have that gasket and have never ran into any issues. Also, if you do have a defective gasket for some reason, Im sure P2R will replace it for you
cycdaniel
Dec 17, 2019 10:58 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
TLDude876
Dec 28, 2016 03:18 PM
Mike Bertram
Sep 10, 2015 09:27 AM
NSolace
Sep 3, 2015 08:14 PM
