Idling problem
Old Dec 5, 2002 | 04:54 PM
CrazyHorse's Avatar
Idling problem
Have 6spd MT and am having idling problems when the car is ice cold. It goes from about 1k to 2k up and down when I don't even have my foot on the gas. Anyone have a similar problem? When the car warms up it is fine. I made an appointment with PAA to have them install my Comptech headers, fix the emergency brake (Becoming way to loose), and check out the idling problem.
Old Dec 5, 2002 | 09:38 PM
Wires's Avatar
Re: Idling problem
Nope.. Don't have that problem. The service sheet for the car said you have to let the ECU set the idle when the ECU loses power (battery disconnected, fuses, etc).
Basically, you can do it yourself. Disconnect the battery for a minute to clear the ECU. Start the engine will all the lights, radio, HVAC, etc off. Let it warm up until the engine fan cycles twice (indicates operating temp.). Idle it for 10 minutes, and then it's done.
You can try that to see if it fixes you problem.
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
TL14
Sep 24, 2015 04:37 PM
