icebox vs stock?
02 SSM CL-S
icebox vs stock?
Hello all,
I installed an aem intake on my 02 sl-c, and boy its LOUD!!!!! after having it for about 2 months I have decided its too loud... So now my question...do I get the ice box or just go back to stock???? what do you guys think????
Thanks!
Aaron
Thanks!
Aaron
I would never pay $280 for a damn intake, that's retarded. If you're going to get the icebox just keep the stock intake and remove the resonator, there, now you have the same sound.
Edit: I don't mean to insult anyone posting here, I just dislike Comptech and their insane prices for just about everything.
k&n is the best route i think. quiet at normal acceleration, and yet gives a nice grunt when you step on it. hell theres only a few bolts to remove the resonator. bad thing is that side of the bumper is left a little flimsy
Yea I am also confused...I have no flimsy bumper characteristics.
Like mentioned above...you might want to make sure all your nuts and bolts are there..literally. ha ha
Is there a DIY on resonator removal? I searched, and found a post with cltypeslow linking to a DIY for resonator removal, but all it showed was how to remove the bumper.
What exactly is the resonator anyway...i'm new to this stuff...but i'd be willing to try it, it seems easy enough from what i've heard so far.
edit: oh yeah, how do i find out if this is legal in my state(s) or not? i plan on replacing the air filter with a k&n one
Originally Posted by cltypeSLOW
green machine tried to tell you this already. you should at least read your own threads. PS this topic has been covered MANY times before so next time just try searching a key word or two. for instance....you could have just searched "resonator" and found a ton of results. ok heres the DIY
https://acurazine.com/forums/showthread.php?t=183710
while you are at it...read this ENTIRE THREAD
https://acurazine.com/forums/acurazine-clubs-meets-15/chicago-cruisin-66-car-show-invite-181322/
The resonator is on the left side (drivers side) behind the bumper and attached to the lower part of the airbox (where the air filter is located)and held on with 2 bolts. Its the big black box. Simply remove the bumper, remove the 2 bolts and remove.
There is no reason it wouldnt be legal. It has no effect on emissions.
Actually, there is no need to remove the bumper. Just jack up the left front side of your car, and remove the clips and fasteners of the underside splash-guards and the first few of the fenderwell splashguard. There should be two points where the resonator is bolted/screwed in to place. Remove those and pull the resonator out of the bottom of the air filter housing. In all honesty, removing the resonator does not make a difference in my opinion. I put mine back in. before that, I had a CIA-which does make your VTEC sound more aggressive at higher RPM's (I burned A LOT of gas by punching the throttle just to hear the sexy sound!).
Moderator Alumnus
an adult perspective
Have had the ICEBOX for over 4 years, and wouldn't have done it any other way. Filter gets cleaned/oiled basically once a year, after over 30,000 mile of driving. Sound is not at all intrusive like other CAI's, plus I think it would be inappropriate for this particular car. Now, the M2W I put in my vette is a different story altogether.
ok ok, so i removed my resonator, but should i also remove the pipe that runs from the airbox to the resonator and is shaped like a U with a down pipe for the resonator?
DerrickW
11-15-2015 05:52 PM
